IP Keepalive
jonesc
Is it possible to configure a router to automatically ping (or send some other sort of IP keepalive) an IP address every so often, and base the status of a virtual interface on whether these keepalives are regularly received? I recall seeing this in a TAC Newsletter several years ago, but have not been able to find anything referencing this. At the bare minimum, if you can just tell me what keywords I should search Google or Cisco for, I would greatly appreciate it.
Clint Jones
pkhatri
Level 11
Level 11
Hi Clint,
You might want to have a look at Advanced Object Tracking:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t15/fthsrptk.htm
Paresh
