ip nat destination nat
hirentailor
We have to do a destination nat & planning to use ip nat outside source static.
Is it necessary that session initiation should happen from outside only? in our case it will be from inside network.Will it work if session initiates from inside network.
milan.kulik
Level 10
Level 10
IMHO, as long as you use static NAT, it should work.
BR,
Milan
