IP NAT for Web Server---Cisco 3640
woodjl1650
I am trying to setup my web server, but I am having trouble trying to figure out how to direct outside traffic to that server and not to the router itself when the WAN IP address is entered.
Topology=  Cable Modem -----> Cisco 3640 ----> Switch -----> WinServ1 (Web Server)
My current show run:
3640-Internet#show run
Building configuration...
Current configuration : 1771 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
hostname 3640-Internet
boot-start-marker
boot system flash:1
boot system flash c3640-ik9o3s-mz.124-7h.bin
boot-end-marker
no aaa new-model
memory-size iomem 25
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.150
ip dhcp pool 192.168.2.0/24
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 8.8.8.8 8.8.4.4
username 9
interface FastEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Ethernet3/0
no ip address
shutdown
half-duplex
interface Ethernet3/1
no ip address
shutdown
half-duplex
ip http server
ip http authentication local
ip forward-protocol nd
ip nat inside source list 15 interface FastEthernet0/0 overload
access-list 15 permit 192.169.2.0 0.0.0.255
access-list 15 permit 192.168.2.0 0.0.0.255
snmp-server community public RO
snmp-server community private RW
snmp-server enable traps tty
control-plane
dial-peer cor custom
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
end
3640-Internet#
yes you should try it from an outside address because hairpinning is not available on this type of router, the only way to access it from outside would be using DNS doctoring by using a fqdn and having the record on an external DNS server.
Regards.
Alain
10 Replies 10
cadet alain
ip nat inside source static tcp x.x.x.x 80 interface f0/0 80   where x.x.x.x is the inside address of the web server
Regards.
Alain
Cool, just applied that and still I get passed the the SDM and not the web server.  When I type me web address it goes to the SDM of the router and not the web server.  I am using my inside network to try and test this out, do I need to try and access it via differnet outside IP address?
I went to my domain host, godaddy.com and config it to forward you to my outside IP address when the web address is typed.  That part seems to be working.
Any ideas?
Regards.
Alain
could you explain how to FQDN?
FQDN= full dns name so just have a A record on an external DNS server and in your browser type the DNS name instead of the IP and the router will rewrite the DNS reply to the private IP of your server.
Regards.
Alain.
I think I have that done already.  Like I said I use www.godaddy.com for the web host.  I went in and modified the A record to:  @ (wan ip address).  So all I should have to do now, is type the www.jkkcc.com address in the web page and it should take me to my server.  But when I do that, I get the router instead (the SDM login page).  I applies the NAT policy you provided a minute ago and still get the same thing.
if this help, here is the show run again:
User Access Verification
Username: woodjl1650
Password:
Current configuration : 1691 bytes
version 12.4
boot-start-marker
boot system flash:1
boot-end-marker
no aaa new-model
ip cef
username woodjl1650 privilege 15 password 0 henry999
ip address dhcp
ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
ip nat inside
ip route-cache flow
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
half-duplex
no ip address
shutdown
half-duplex
ip http server
ip nat inside source static tcp 192.168.2.128 80 interface FastEthernet0/0 80
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
end
3640-Internet#
if you could only keep it one thread this would be great. So maybe your IOS version doesn't support dns doctoring?
Regards.
Alain.
Help needed on my post. Thank you.
How are you? I am in big trouble I am unable to configure 1 web server which is inside my organization. Can you please send your router running configuration. I need to configure it is very urgent please. Thank you.
Also Have a look at the links. Let me know Is there anything that is wrong with my configuration. Thank you.
https://supportforums.cisco.com/thread/2231684
https://learningnetwork.cisco.com/message/320091#320091
However, I can access web server Inside the organization but not from outside. Thank you.
