ip nat over two pvc with cisco 876w
andre_hro
I will connect my provider over 2 pvi.
I create two dialer. Each dialer gets a dynamic ip from my provider.
I would like to route all packages from 172.16.1.0 to dialer 1 and all packages from 172.16.2.0 to dialer 2.
I have create the following setup see attachment. I can route from 172.16.1.0 to dialer 1 but not form the second network two the second dialer. Can someone give me assistance?
with best regards
André
Edison Ortiz
Remove the highlighted portion of the config:
route-map NAT-VoipDailer permit 10
description NAT route-map for dialer 2
match ip address ACL-NAT-VoipNet
match interface Dialer2
route-map NAT-DataDailer permit 10
description NAT route-map for dailer 1
match ip address ACL-NAT-DataNet
match interface Dialer1
and modify the following entry:
ip access-list extended PBR-Traffic-Divert
permit tcp 172.16.2.0 0.0.0.255 any
with:
permit ip 172.16.2.0 0.0.0.255 any
HTH,
__
Edison.
