ip ospf network command options
omal
I'm a little confused with these five options, and wondering if someone could help me to clarify them.
I read in a book and it says there are five modes as follows:
1) Broadcast (Cisco Extension)
2) non-Broadcast (RFC-compliant mode)
3) Point-to-multipoint (RFC-compliant mode)
4) point-to-multipoint non-broadcast (Cisco extension)
5) POint-to-point (Cisco extension)
Can someone please clarify when exactly do we use these modes?
If the mode 'broadcast' is a Cisco extension, then a non-Cisco router in a LAN will not elect a DR and BDR, is it?
What is the difference between 'point-to-multipoint' and 'point-to-multipoint non-broadcast' modes? I mean which one elects the DR and BDR automatically and why we need to choose between the two? In other words, what is the advantage of one over the other?
Thanks a lot in advance!
sourabhagarwal
Level 4
Level 4
Hope these URLs will answer to your queries.
http://www.riverstonenet.com/support/ospf/nettypes.htm#_Toc11038541
http://www.cisco.com/warp/public/104/3.html
hope to help ... rate if it does ...
Thanks a lot for your post. It helped me to a certain extend. It would have been better if the fist URL's note was explained with Cisco routers. Anyway I got some sort of an idea. Thanks a lot.
prashant_2006
sory i dont know tell u later
