IP Redirect
fundataca
I have a problem which i hope someone could shed some light on.
Currently I have 1 external IP address a  Webserver in the DMZ and a Exchange\OWA server in the LAN the router is a cisco 881.
We have a port rediorect rule to send all 443 traffic to the Exchange\OWA server in thye LAN.
I need to add SSL to the webserver and have ssl traffic go to both. Is there away to do this.
paolo bevilacqua
Yes. But for one server, you will have to use a non-standard port.
If you do not want to use non-standard port, you need more addresses from ISP, or move servers to hosting facility.
paolo bevilacqua
This is what I figured.
