ip rip advertise
wingu
In the configuration of serial interface, there is "ip rip advertise 5". I think this is the default command. I want to know what exactly means. I assume this is related on rip information advertise period.
I couldn't find the infomation related this on cisco homepage.
Thank you.
2 Accepted Solutions
jolmo
Level 4
Level 4
This command changes the default of 30 seconds to the value configured using "ip rip advertise [interval]" to send the rip updates via that interface.
With that command, each interface can have a different update interval.
Hope this helps
Just to add , In some series of IOS , as soon as you change the rip timers under rip config , all the interface would have that command getting added " ip rip advertise "
In some series , we need to manually add the command , so that you dont have a mismatch in sending and receiving updates
regards
vanesh k
jolmo
Level 4
Level 4
Hope this helps
regards
vanesh k
A bit late to the party, thanks :)
