IP Routing 3850 12s-2
Sadam
Thanks for your help.
I need to connect internet to my network my ISP router IP 192.168.1.1
also share internet to my network vlan's
Vlan details.
Vlan 110 Data,120 IP-Phone,130 IP-CCTV,100 MGMT
Building configuration...
Current configuration : 4486 bytes
version 15.2
no service pad
service compress-config
hostname SW1
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 cisco@123
enable password cisco
username amps password 0 cisco
no aaa new-model
switch 1 provision ws-c3850-12s
ip routing
diagnostic bootup level minimal
spanning-tree mode pvst
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
no ip address
shutdown
interface Vlan110
ip address 192.168.110.1 255.255.255.0
interface Vlan120
ip address 192.168.120.1 255.255.255.0
interface Vlan130
ip address 192.168.130.1 255.255.255.0
interface Vlan100
ip address 172.168.100.1 255.255.255.0
8 Replies 8
M. G.
Hi ,
You need a default route pointing to your ISP (ip route 0.0.0.0 0.0 0.0.0.0 192.168.0.1) and your ISP needs to know how to reach you VLANs (needs to configure your switch to be  next hop for you LAN VLANs ).
Second option is that you do NAT for all local VLANs to your ISP pointing IP. In that case default route is enough.
regards,
mg
Now i can able to ping my router
configuration time i can ping 8.8.8.8 after the configuration done i can't ping 8.8.8.8
but still i can ping my router 192.168.1.1
also my edge sw sf300 not able ping 192.168.1.1
Vlan details.
version 15.2
no service pad
hostname SW1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip routing
redundancy
mode sso
no ip address
negotiation auto
description *** Internet ***
no switchport
ip address 192.168.1.2 255.255.255.0
interface Vlan1
no ip address
shutdown
interface Vlan110
interface Vlan120
interface Vlan130
interface Vlan100
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.1
You still need NAT in order to be able to reach outside with your VLAN ip subnets.
interface GigabitEthernet1/0/x
 no switchport
 ip address x.x.x.x y.y.y.y
 ip nat outside
interface Vlan10x
 ip address x.x.x.x 255.255.255.0
 ip nat inside
interface Vlan11x
 ip address y.y.y.y 255.255.255.0
 ip nat inside
access-list 1 permit <VLAN 1xx IP subnets with wildcard>
ip default-gateway 192.168.0.1
ip nat inside source list 1 interface GigabitEthernet1/0/x overload
ip route 0.0.0.0 0.0.0.0 10.1.1.254
Deepak Kumar
Below are the changes in your switch configuration:
Route:
IP route 0.0.0.0 0.0.0.0 192.168.1.1
Interface configuration on Switch which is connected to ISP router.
Interface gig x/x/x
Description "Connected to WAN-ISP router"
no switchport
IP address 192.168.1.2 255.255.255.0 <What is your subnet mask>
no shut
If no switch command will not work then
VLAN 10
Name WAN Router Connection
Interface gig x/x/x
switchport mode access
switchport access vlan 10
no shut
NAT:
I think NAT is already configured on ISP router because of its supply private IP to you. You must add your local subnet in NAT ACL on your ISP modem.  You can't configure NAT on this switch. If you are facing any difficulty then please share the ISP router configuration. We will help you.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I can't access the ISP router and also request to get the configuration about the ISP router
but i have checked the ISP router directly via laptop that will also ping only ISP router IP, Not able to ping google's DNS 8.8.8.8
Please share the router model number and brand. Is it Cisco router? And reconnect your laptop direct to ISP modem and configure IP on your laptop as
IP address: 192.168.1.3/255.255.255.0
Gateway: 192.168.1.1
DNS" 192.168.1.1/8.8.8.8
and run a CMD "Tracert 8.8.8.8" and share the Output.
Deepak Kumar
Deepak Kumar,
Hello
your switch cannot perform NAT
and as such you need to be able to translate your vlan subnets but as your isp is providing the nat then you either need to add your vlan subnets to the isp plus some static routes  OR
add a rtr between your isp rtr and your switch and apply Nat on that
res
paul
Kind Regards
Paul
Thanks for your kind of replay.
Sorry for the delay frnds,
Now i can able ping 8.8.8.8 in my 3850 sw but not able to ping 8.8.8.8 in my sf300 sw.
this my sw conf details.
Cisco 3850 12s
Current configuration : 5202 bytes
version 15.2
no service pad
hostname SW1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
username amps password 0 cisco@123
no aaa new-model
ip routing
ip dhcp excluded-address 192.168.110.1
ip dhcp excluded-address 192.168.110.2 192.168.110.10
ip dhcp pool DATA
network 192.168.110.0 255.255.255.0
default-router 172.168.100.1
dns-server 8.8.8.8
qos queue-softmax-multiplier 100
redundancy
mode sso
no ip address
negotiation auto
description *** Uplink From MEZFLR-SW3 ***
description *** Uplink From GND-FLR-IDF1-SW1 ***
description *** Uplink From GND-FLR-IDF1-SW2 ***
description *** Uplink From GND-FLR-IDF2-SW1 ***
description *** Uplink From 1ST-FLR-IDF3-SW1 ***
description *** Uplink From 1ST-FLR-IDF4-SW1 ***
description *** Uplink From 2ND-FLR-IDF6-SW1 ***
description *** Uplink From 2ND-FLR-IDF5-SW1 ***
no switchport
interface Vlan1
no ip address
shutdown
interface Vlan110
interface Vlan120
interface Vlan130
interface Vlan100
ip http server
line con 0
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
Cisco SF300
config-file-header
MZFLR-IDF1-SW3
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 110,120,130-132,100
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname MZFLR-IDF1-SW3
enable password level 15 encrypted
username cisco password encrypted privilege 15
ip telnet server
interface vlan 100
ip address 172.168.100.2 255.255.255.0
no ip address dhcp
interface fastethernet1
switchport access vlan 120
interface fastethernet19
switchport access vlan 131
interface gigabitethernet1
switchport trunk allowed vlan add 110,120,130-132,100
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
switchport access vlan 100
exit
ip default-gateway 172.168.100.1
