ip sla auto discovery does not exist in router 4331.
fri
Hi All,
I have an issue for my router version is ISO XE 3.16 with Appx license installed.
when i input the command in global mode : ip sla auto discovery the command seen does not exist in the router.
when i show ip sla auto discovery its show disable, can someone know how to enable the auto discovery?
Please advise.
6 Replies 6
do you have any options when you type 'ip sla auto template type' ?
Hi Georg,
Its does not have command auto..
Hi All,
Any 1 know how can enable the IP SLA auto discovery in IOS-XE?
jvujcich
I have this problem too with a C8200-1N-4T  (IOS XE Software, Version 17.06.01a).
ip sla has no "auto discovery" option and IP SLAs auto-discovery status shows Disabled.
8200(config)#ip sla ?
<1-2147483647> Entry Number
enable      Enable Event Notifications
endpoint-list     Endpoint list configuration
ethernet-monitor       IP SLAs Auto Ethernet Configuration
group                     Group Configuration or Group Scheduling
key-chain                     Use MD5 Authentication for IP SLAs Control Messages
logging                         Enable Syslog
low-memory                  Configure Low Water Memory Mark
periodic                    Periodically resolves the IPSLA hostnames
reaction-configuration         IP SLAs Reaction-Configuration
reaction-trigger                   IP SLAs Trigger Assignment
reset                                    IP SLAs Reset
responder                                      Enable IP SLAs Responder
restart                               Restart An Active Entry
schedule                   Entry Scheduling
server                IPPM server configuration
snmp             Set SNMP extensions
dyoma
Hi All
Same problem, is there a solution?
Make new post it better
MHM
