IP SLA DHCP keep on failing
vyas.nilay
Please help.. I am trying to troubleshoot an a possible issue with DHCP.
I have setup my IP SLA but it is only 50% success and keep on failing with Over threshold.
I am not too good with IP SLA so I might be missing someinformations.
RTT is too high but when I run the ICMP on the same host it is normal 1to 3 ms.
Details:
IPSLA operation id: 2
Latest RTT: 8335 milliseconds
Latest operation start time: 15:37:23 NZST Wed Jun 17 2020
Latest operation return code: Over threshold
Number of successes: 17
Number of failures: 0
Operation time to live: Forever
Configuration:
ip sla 2
dhcp 10.7.19.11 source-ip 10.7.0.253
timeout 60000
threshold 6000
history buckets-kept 35
ip sla schedule 2 life forever start-time now
Please let me know if you require more information.
Nilay.
the IP SLA looks good actually. Try and change the threshold and timeout values:
ip sla 2
timeout 10000
threshold 10000
Sure I will make it 15000 as Threshold to see what happens..
Is there any way to log over the threshold respond?? as I can leave it and check if goes over the threshold.
Nilay.
you could create a reaction that would generate a syslog message. It don't think you can react to a threshold violation, but if you set the timeout and the threshold to the same value, it essentially reacts to both:
ip sla reaction-configuration 2 react timeout threshold-type immediate action-type trapOnly
