IKEv2 site to site vpn with nat on Cisco ISR
mihai.vasc
Hello all,
I have to configure an IKEv2 site to site vpn on a Cisco ISR. So far everything ok.
The problem is that I cannot use internal IP subnets as they are overlapping with the remote ones. I want to configure NAT for this vpn and to translate traffic before sending it over the vpn, to one specific private IP that is not overlapping .
Can someone help with a template config or documentation for this?
I know how would look like on ASA but not on ISR.
Thanks in advance!
2 Accepted Solutions
you need a NAT pool and policy NAT involving a route map. Have a look at the document below (it is for IKEv1, but v2 should be similar), or post the running configuration of your routers, so we can fill in the necessary bits and pieces...
https://www.booches.nl/2009/01/policy-nat-on-cisco-router/
Deepak Kumar
This link will help you more: https://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/107992-IOSRouter-overlapping.html
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
Deepak Kumar,
mihai.vasc
This is the current config without NAT. Any help please to make NAT work in this case?
IKEv2 configuration looks like:
crypto ikev2 proposal PROPOSAL
encryption aes-cbc-256
integrity sha256
group 16
crypto ikev2 policy POL_IKEv2
proposal PROPOSAL
crypto ikev2 keyring KEYRING
peer PEER
address A.B.C.D
pre-shared-key local ***
pre-shared-key remote ***
crypto ikev2 profile PROFILE
match identity remote address A.B.C.D 255.255.255.255
authentication remote pre-share
authentication local pre-share
keyring local KEYRING
crypto ipsec transform-set TS esp-aes 256 esp-sha256-hmac
mode tunnel
crypto map CMAP 36 ipsec-isakmp
set peer A.B.C.D
set security-association lifetime seconds 3600
set transform-set TS
set ikev2-profile PROFILE
match address ACL
interface GigabitEthernet0/0/0
description WAN
crypto map CMAP
interface GigabitEthernet0/0/1
description LAN
ip access-list extended ACL
permit ip host 192.168.186.0 0.0.0.255 10.1.1.0 0.0.0.255
So applying the ikev1 solutions seems to work just fine. Additional lines of config:
ip nat pool INSIDE_GLOBAL_SUBNET 192.168.186.2 192.168.186.251 netmask 255.255.255.0
ip nat inside source list TRAFFIC_TO_BE_TRANSLATED pool INSIDE_GLOBAL_SUBNET overload
ip access-list extended TRAFFIC_TO_BE_TRANSLATED
  permit ip 10.1.1.0 0.0.0.255 172.16.1.0 0.0.0.255
Thanks for your help
