IP SLA Dual ISP PBR Need Help
bennettg
I need help with using IP SLA to route traffic to backup ISP when primary is down and revert back to primary when it comes back up.
We have two buildings each containing a core switch (3850) and a FTD firewall  connected to a different ISP.  Each core switch has a default route pointing to its directly connected firewall.  Each firewall has a static route - to route internal traffic back to the core switch its directly connected to. Firewalls are managed independently without FMC so I don’t have access to IP SLA on the firewall.
ISP 1 – FTD -- Core Site1   ---------- TenGig backbone ----------- Core Site2 – FTD--ISP2
The server VLAN uses Site 1 core switch and firewall to access the Internet.
All other traffic uses Site 2 core switch and firewall.  I’m using HSRP to set priority on a VLAN so traffic defaults out a specific firewall based on the master role for that VLAN on a switch.  The Firewall inside subnet/VLAN is not using HSRP. Originally, I thought HSRP was the issue so I removed HSRP from inside firewall VLAN.  This didn’t fix the issue.
Here’s my issue, if I shutdown the directly connected interface from Core switch to firewall, IP SLA works (traffic fails over to floating static route and routes out ISP in other building.  If the failure is behind the core switch (e.g. uplink from firewall outside interface to ISP CPE), there is flapping and default route bounces back and forth between the core switches because ping is using default route instead of only sending out a specific interface (that’s what I suspect anyway).
Below is my config.
Site 1
track 1 ip sla 1 reachability
ip route 0.0.0.0 0.0.0.0 10.XX.YY.2 track 1
ip route 0.0.0.0 0.0.0.0 10.XX.YY.1 200
ip access-list extended ping-gw
 permit icmp any host 4.2.2.2
ip sla 1
 icmp-echo 4.2.2.2 source-interface TenGigabitEthernet1/1/1
 threshold 5
 frequency 5
ip sla schedule 1 life forever start-time now
ip sla logging traps
route-map DEFAULT-ROUTE-POLICY permit 10
 match ip address ping-gw
 set ip default next-hop 10.33.90.2
Site 2
 delay down 5 up 10
ip route 0.0.0.0 0.0.0.0 10.XX.YY.1 track 1
ip route 0.0.0.0 0.0.0.0 10.XX.YY.2 50
 permit icmp any host 8.8.8.8
ip sla 1
 icmp-echo 8.8.8.8 source-interface TenGigabitEthernet1/1/1
 threshold 10
 frequency 5
 set ip default next-hop 10.33.90.1
I’ve tried different options with “set” in the route map to (set interface te1/1/1, set ip next-hop verify-availability 8.8.8.8 1 track 1).  None of these seem to bypass the default route in the routing table.
Looking for help to make this work correctly.
2 Accepted Solutions
Hello
Append this and test again-
no route-map DEFAULT-ROUTE-POLICY
access-list 100 permit icmp host <source ip> host 8.8.8.8 echo
match ip address 100
set ip next-hop 10.33.90.x
set interface Null0
ip local policy route-map DEFAULT-ROUTE-POLICY
Kind Regards
Paul
Hello
You dont apply the route-map to any interface, as its a control plane feature the route-map is only locally significant as such ip local policy route-map is a global command
Kind Regards
Paul
6 Replies 6
Hello
set interface Null0
Kind Regards
Paul
I tried that before and the "set interface null0" generates the following error in the log and I'm unable to apply the route-map policy to the VLAN interface.  The above command is valid for configuring the route-map though.
%FMANRP_PBR-3-UNSUPPORTED_RMAP: Route-map DEFAULT-ROUTE-POLICY has unsupported options for Policy-Based Routing. It has been removed from the interface, if applied.
Hello
Kind Regards
Paul
why don't you use the simple EEM scripts below to add/remove the respective default route based on the track state ?
event manager applet DEFAULT_ROUTE_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "conf t"
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 10.XX.YY.2
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 10.XX.YY.1"
action 5.0 cli command "end"
event manager applet DEFAULT_ROUTE_UP
event track 1 state up
action 3.0 cli command "no ip route 0.0.0.0 0.0.0.0 10.XX.YY.1
action 4.0 cli command "ip route 0.0.0.0 0.0.0.0 10.XX.YY.2"
bennettg
Thanks Paul, I'll give it a try.
