09-22-2011 04:10 AM - edited 03-04-2019 01:41 PM
I have the below setup and I want to get a Cisco router to enable failover between my ISP links.
At the branch end, failover happens as there are only connected to the Headoffice MPLS lines.
Whereas in the Headoffice, failover does not happen, and we have been manually changing the priority of the route.
The NPA that we have is to introduce a Cisco router between the HO Firewall and the ISP MPLS links inorder to actively monitor the the two paths and automatically choose the secondary ISP incase of primary link failure.
Fortigate 300A - Headoffice
Foritgate 50B - Branch
Could you please suggest a suitable router that can cater to my requirement [it is a small business] and also help me configure this setup?
Thanks!!
Solved! Go to Solution.
09-24-2011 01:55 AM
Yes,
you can do it in GNS3.
Regards.
Alain.
09-24-2011 04:29 AM
Thanks Alain!
GNS3 doesn't have 1800 or 1800 series routers
09-24-2011 05:19 AM
This isn't working!
09-24-2011 07:02 AM
use a 3660 router.what is important is IOS version that supports the feature.
I already did it with GNS3 and it works.
Alain.
10-03-2011 07:37 AM
I am trying to configure IP SLA responder on a Cisco 1841, IOS 12.4T.
corp(config)#ip sla responder tc
corp(config)#ip sla responder tcp-connect ?
ipaddress Permanent address
port Permanent port
When I give the IP address as 172.16.1.2 255.255.255.252, it prompts me for the permanent port.
The port that is connected to this is fa0/0, 172.16.1.1.
I am not able to enter the same, is there a mistake in what I am trying to do?
08-29-2012 02:45 PM
All,
When there is a failover does it change the entry in the route table to the failover IP?
