IP SLA ICMP-ECHO for a range of request-data-size
Ivan Uribe
Hello there!
I had an issue with a couple of WAN links, issue was related with packet loss on the ISP cloud. When I was testing, I noticed that packet loss was occurred on pings with a size higher than 1300, issue was resolved by the ISP but customers experienced slowness for couple of hours which is unacceptable, now we installed a backup link and I would like to configure IP SLA ICMP-ECHO to track the packet loss and switch to the backup link. I know it could be something quick and easy like the following:
ip sla 10
icmp-echo 5.5.5.5 source-ip 2.2.2.2
frecuency 300
request-data-size 1300
tos 160
tag ISP_LocationAtoB
ip sla schedule 10 life forever start-time now
But is there a way to setup an icmp-echo operation for a range of sizes (1000, 1300, 1500) and monitor the response in the same SLA operation???
Philip D'Ath
You would need to setup up multiple IP SLA's, and then monitor them as a group.  For example, something like:
track 10 ip sla 10
track 20 ip sla 20
track 100 list boolean or
object 10
object 20
thanks Philip, I'll try and see how it works.
Regards!
