VLANs
juanc.marquez
I am new using Cisco Meraki devices and, I would like to know whether is possible to configure a port on the switch that allow different VLANs, (ok that is easy one just configuring the port as trunk) but what I want is: that port is going to be used for different people, from different departments, and I don't know if with the meraki devices I can allow to the device (by mac address) select to which Vlan they can have access.
I don't know if that makes sense?
Carlos
Philip D'Ath
What you want is an access port, which dynamically selects the VLAN based on who or what is plugged in.
I have never used Meraki in this way, but what you probably want is 802.1x.
https://docs.meraki.com/pages/viewpage.action?pageId=7438344
Philip D'Ath
Thanks for your answer Philip, I will take a look to the link.
Cheers  :)
