10-29-2013 06:18 AM - edited 03-04-2019 09:26 PM
I'm a Cisco novice looking at how to provide an automatic failover solution for a primrary fibre link with a secondary VSAT connection. I have been looking at IP SLA which looks straightforward, however the data being sent over the fibre has been seperated into two layer 2 vlans. Is it possible to incorporate layer 2 vlans into an IP SLA setup?
The hardware in question are Cisco 2811 routers running IOS version 12.3(8)T7
10-29-2013 06:41 AM
Bear in mind that IP SLA is dealing with IP which operates at layer 3. A VLAN operates at layer 2 and I do not know of any way to have IP SLA process a layer 2 operation.
But perhaps the VLAN has an interface vlan x? This would provide a layer 3 interface for that VLAN and would route traffic for the VLAN. In that case IP SLA could examine reachability of the vlan interface and indirectly process for the layer 2 VLAN.
Rick
10-29-2013 07:29 AM
The VLANs are phyically configured on FE ports on a switching module but with no ip address sadly.
Is there any other methodology of providing failover for layer 2 VLANs?
