I'm trying to configure a router with the ip sla command, but there is something strange: when I type the command ip sla 1, this is what appears:
ip sla 1
%Invalid input detected at '^'marker
If I try to check the ip sla command, this is the only info appearing:
Router(config)# ip sla ?
key-chain Use MD5 authetication for IP SLAs Control Messages
responder Enable IP SLAs Responder
I'm attaching a file with the info regarding the IOS version and the info regarding another router, same model (2911) and same IOS version and it has more options at the ip sla command.
Could anybody help me? this is really wierd!!!!
