IP SLA Monitor maximum object counts ASA 9.1.xx
LPalko
Dear Cisco Experts,
Is there any up to date information about maximum counts of SLA Monitor object in a single device running ASA 9.1.xx branch image?
I found a pretty old pdf wich says:
"SLA Monitor ID The ID number of the SLA operation. Values range from 1 to 2147483647. You can create a maximum of 2000 SLA operations on a device. Each ID number must be unique to the policy and the device configuration"
https://www.cisco.com/c/en/us/td/docs/security/security_management/cisco_security_manager/security_manager/4-0/user/guide/CSMUserGuide_wrapper/pxSLAobjects.pdf
... however I hope there are some improvement in newer images.
Laszlo
Diana Karolina Rojas
Good morning estimated,
I have found this article: https://www.cisco.com/c/en/us/td/docs/security/asa/asa-command-reference/S/cmdref3/s15.html as you can see it have been updated in april 20 2018, and is for Cisco ASA 5500X Firewalls, it seems like this numbers SLA operations apears to be independent form the IOS.
Please do not forget to rate useful post.
Best Regards,
Best Regards,
Many thanks!
Laszlo
