IP SLA Responder on Catalyst 6500
s-durando
Hi everybody,
I have a Cat6500 IOS train 12.2SXD in a multi-vrf context. I'd like to configure it as rtr responder but it seems that the rtr responder is not vrf aware.
Is it necessary to add specific configuration?
Stefano
b.hsu
Level 5
Level 5
The SAA Responder (RTR Responder) is also VRF Aware. A bit you have to modified your configuration.
If you want to know more click below link:
http://cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a008060c813.html
I'm sorry but the feature you talked about is not supported on Cat6500 platforms
Stefano
