IP SLA : set ip next hope
medharrak
I'm configuring IP SLA in Cisco Router to ping 8.8.8.8 , any idea how to specify the ip next hope?
Thank you
Hello
if i understand you wish to make sure ip sla icmp probe to 8.8.8.8 is only reachable via a certain default path possibly the active default path and negate the probe reaching 8,8,8.8 via an alternate path if/when the current default path becomes unavailable?
example1:
ip sla 1
icmp-echo 8.8.8.8 source-interface fa0/1
timeout 1000
threshold 2000
frequency 15
ip sla schedule 1 start now life forever
track 10 rtr1 reachabilty
ip route 0.0.0.0 0.0.0.0 fa0/1 x.x.x.x track10  name primary link
ip route 0.0.0.0 0.0.0.0 fa0/0 x.x.x.x 2  name backup link
ip route 8.8.8.8 255.255.255.255 Null0 2
example2:
same ip sla as in example 1
access-list 100  permit icmp host <source ip> host 8.8.8.8 echo
route-map ipsla
match ip address 100
set ip next-hop (next hop of interface fa0/1)
set interface Null0
ip local policy route-map ipsla
ip route 0.0.0.0 0.0.0.0 fa0/1 <nexthop ip> track 10 name primary link
ip route 0.0.0.0 0.0.0.0 fa0/0 <nexthop ip> 2 name backup link
Kind Regards
Paul
6 Replies 6
balaji.bandi
I am may interpreting wrong here ? what are you looking for next hop syntax ?
example :
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/861-cisco-router-pbr-ipsla-auto-redirect.html
BB
medharrak
I'm looking to know if there is a way to specify which output interface to take.
I see in your example that route-map is used
Sure if you have different path to go out, yes you need to choose which path to choose to reach destination and based on the results take action.
BB
medharrak
but my question if how to do it , there is No "ip next hop" command in ip sla .
so what I did is : I added a route to 8.8.8.8/32 to go through a specific interface
pman
Your next hop is determined by the routing table.
For example if to get to 8.8.8.8 you exit through Gi0/0/0 at IP address 192.168.1.1/24 (this ip configured on Gi0/0/0):
R1#show ip route 8.8.8.8
Routing entry for 8.8.8.8/32
Last update from 192.168.1.2 on GigabitEthernet0/0/0, 00:17:00 ago
If you work with static routing you can specify the route and the alternate interface through which the next hop should be found:
ip route 0.0.0.0 0.0.0.0 Gi0/0/0
https://www.cisco.com/c/en/us/support/docs/dial-access/floating-static-route/118263-technote-nexthop-00.html#anc5
Hello
example1:
ip sla 1
timeout 1000
threshold 2000
frequency 15
example2:
route-map ipsla
set interface Null0
Kind Regards
Paul
