IP SLA Track and Multiple time.
Yong Peng
Greeting.
I'd like to configure IP SLA Track and Multiple time.
the special requirement is:
the track should be multiple times, that means, if the first track fails, the track status is still up, if the track fails 3 times, the track status is down.
that is similar with ospf hello process, one time hello missing doesn't cause network converging.
Below configuration doesn't work. it's one time track ( the first track fails, the track status is donw)
Does anyone know how to configure?
ip sla 123
icmp-echo 123.1.1.1 source-ip 3.1.1.1
request-data-size 128
verify-data
threshold 500
timeout 2000
frequency 10
ip sla schedule 123 life forever start-time now
track 10 ip sla 123 reachability
ip route 1.0.0.0 255.0.0.0 2.2.2.1 track 10
ip route 1.0.0.0 255.0.0.0 2.2.2.2 10
Thanks in advance.
Sindhu_kumar
Hi If you set track delay then it will fine I guess.
delay down 40 up 40
R3#sh track
Track 10
  Response Time Reporter 123 reachability
  Reachability is Up, delayed Down (4 secs remaining)
    3 changes, last change 00:04:40
  Delay up 40 secs, down 40 secs
  Latest operation return code: OK
  Latest RTT (millisecs) 32
  Tracked by:
    STATIC-IP-ROUTING 0
R3#
R3#sh track
Track 10
  Reachability is Up, delayed Down (1 sec remaining)
    3 changes, last change 00:04:44
  Tracked by:
    STATIC-IP-ROUTING 0
R3#
R3#
R3#sh ip route static | i 0.0.0.0/0
S*   0.0.0.0/0 [1/0] via 2.2.2.1
R3#
R3#sh track
Track 10
  Reachability is Down
    4 changes, last change 00:00:01
  Latest operation return code: Timeout
  Tracked by:
    STATIC-IP-ROUTING 0
R3#
R3#
R3#
S*   0.0.0.0/0 [1/0] via 2.2.2.2
R3#
R3#sh track
Track 10
  Reachability is Down, delayed Up (2 sec remaining)
    2 changes, last change 00:11:40
  Latest operation return code: Unknown
  Tracked by:
    STATIC-IP-ROUTING 0
R3#sh track
Track 10
  Reachability is Down, delayed Up (1 sec remaining)
    2 changes, last change 00:11:45
  Tracked by:
    STATIC-IP-ROUTING 0
R3#
R3#sh track
Track 10
  Reachability is Up
    3 changes, last change 00:00:01
  Latest RTT (millisecs) 111
  Tracked by:
    STATIC-IP-ROUTING 0
R3#
R3#
Sindhu_kumar
Hi you can also use Boolean track with a OR.
When track object 5 is down and track object 6 is up at that time track 10 won’t go down.
When track object 6 is down and track object 5 is up at that time track 10 won’t go down.
Track 10 will go down when both the track object 5 & 6 is down.
ip sla 123
verify-data
threshold 500
timeout 2000
frequency 10
ip sla 124
icmp-echo 4.2.2.2 source-ip 3.1.1.1
verify-data
threshold 500
timeout 2000
frequency 10
ip sla schedule 124 life forever start-time now
track 5 ip sla 123 reachability
track 6 ip sla 124 reachability
track 10 list boolean or
object 5
object 6
