ip sla + track feature in the c3925
yanglei110
Dear all
     There is a new cisco3925 router and with IOS version is :"System image file is "flash0:c3900-universalk9-mz.SPA.152-4.M4.bin"  , I want to use the " IP sla + track " feature  , it can't support in the version ,  which version of the c3900 can support the feature that I want to use , and where should I can get from ,
please tell the ways in detail .
thanks in advance !
Hi Lei,
adding to alain....
you need the "DATA" license.  Otherwise you will install routes point to devices that can go down and you will never know it.
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10536_Products_White_Paper.html#wp9000801
I think the (IP sla )command has been updated - rather than 'rtr responder' it's now 'ip sla responder'.
The IP SLA Configuration is different now. I've solved this issue through changing the configuration:
http://www.cradlepoint.com/sites/default/files/productdocs/Cisco_WAN_Failover_Configuration_via_IP_SLA.pdf
Hope it helps.
Reagrds
cadet alain
You need a security or data licence to run IP SLA.You can verify with sh licence which one is working on your router.
Alain
Many thanks
Hi Lei,
adding to alain....
Hope it helps.
Reagrds
