IP Sla tracking and vs or
cisco8887
Level 2
Level 2
All,
And to me means both or more of the object needs to be down and or means either.
I have the following :
Track 1 - RTR (Rechability)
Track 2- RTR (Rechability)
Track 3 - RTR (Rechability)
Now I have track group as follow
Track 100 Or
track1
Track2
Track 200 and
track 100
track 3
WHat is strange is track 100 is up no issues, however track 3 does go down from time to time. This results in track 200 going ip and down where it is and statement.
any thoughts?
5 Replies 5
balaji.bandi
AND – it requires that all the objects defined in the track list to be up.
OR – it requires that at least one object to be up.
what is your goal ?
below case is and (so one of them fail it will action)
Track 200 and
track 100
track 3
can you post show output of each track information.
here explained better way :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipapp/configuration/xe-16-10/iap-xe-16-10-book/iap-eot.html
BB
Would opposite not be true for doen
Down and needs all to be down and down or is if anyone them is doen?
Not sure how these are configured, we need more information and config to suggest best here
BB
follow
notmove
It would assist us higher decide what's the problem if we ought to see configuration of the applicable interfaces from both routers. I have seen issues with the symptoms described the service of jrs tracking bc.
