IP SLA with dual ISP using NAT
Tupe_kunal
Hi All,
I need to configure IP SLA on a router with Dual ISP using NAT. Is the below config right ???
Will this work fine.Pls suggest.
ISP 1- 113.65.12.230 (primary) ----------Interface G0/2
ISP 2- 58.51.18.50 (secondary) ---------Interface G0/1
 ip sla 1
 icmp-echo 4.2.2.2 source-interface G0/2(113.65.12.230)
 timeout 500
 threshold 2
 frequency 3
p sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
delay down 15
delay up 60
route-map SDM_RMAP_1 permit 1
 match ip address NAT-List-1
route-map SDM_RMAP_2 permit 2
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/2 overload
ip nat inside source route-map SDM_RMAP_2 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 113.65.12.229 track 1
ip route 0.0.0.0 0.0.0.0 58.51.18.49  10
ip route 4.2.2.2 255.255.255.255 113.65.12.229 permanent
11 Replies 11
I think there is only a small thing missing:
 match interface Gig 0/2
 match interface Gig 0/1
Hi Karsten,
Thanks for your reply.
Is there anything else other that matching the interface in the route-map ?
Best Regards,
Kunal Tupe
no, only the interface and the traffic that should be natted.
Okay, will perform the changes and get back if i need any assistance.
Cheers !!!
Hello
i have tested your configuration and it works accordingly
res
paul
Kind Regards
Paul
Hi Paul,
The failover works fine.. But once the primary link is up again only the internet traffic reverts to the primary.. the VPN traffic does not switch over.
All the tunnels are still active with the secondary IP.
I manually have to remove the crypto map from the secondary interface and then the tunnel comes up..
What could be the issue.? Need to find a fix and get back to the Customer.
Best regards,
Kunal Tupe
Hi Kartsen,
Once question. Will this work smoothly when my Primary link goes down?
At least for NAT and routing, it should work both over the primary and secondary link. You also have to look at your firewallkng and ACL config. And of course you should test it.
Hi Karsten,
Scenario
I have two Internet Links
I am running an IPSEC VPN tunnel on it
I want to failover the internet as well as VPN traffic on the secondary when the primary link goes down.
Configured IP SLA as mentioned in the previous post.
While testing i made the primary link down and it successfully did failover to the secondary i.e Internet and VPN traffic both.
When i made the primary link up back again only the internet traffic diverted again via primary but the VPN tunnels did not come up on the Primary link
When i removed the crypto map from the secondary interface the traffic diverted via primary (testing purpose)
What could be the issue ?
Below is the conf of the interfaces as well
 ip sla 1
 timeout 500
 threshold 2
 frequency 3
delay down 15
delay up 60
 match interface G0/2
 match interface G0/1
 description ** 20MB SingTel BizLink  CN# ETH00047190SNG **
 bandwidth 20480
 ip address 58.51.18.50 255.255.255.252
 ip access-group ProtectWAN_SHORT in
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow egress
 ip nat outside
 ip virtual-reassembly in
 load-interval 30
 duplex full
 speed 100
 no mop enabled
 crypto map My_vpn
 description ### L3 ###
 ip address 113.65.12.230 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow egress
 ip nat outside
 load-interval 30
 duplex auto
 speed auto
 crypto map My_vpn
Instead of thinking about this problem, there could be a better way to achieve this.
You could configure VTIs (virtual tunnel interfaces) over both links, run a routing protocol over the tunnels and let the routing do the decision which tunnel is available.
the client requires it to work that way :(
