IP SOURCE GUARD not work on EVE-NG
dragonhunt9111
Hello friends,
I test IP source guard on EVE-NG as below topo:
I config on switch DHCP snooping and IP source guard. then VPC get IP from DHCP server (R1) ok
But dont know why after I enable IP source guard, VPC3 can not
ping to R1 192.168.1.1
(If i remove
IP SG
command, ping is ok again)
This is showing on switch, it seems OK.
This below is my configuration on Sw:
ip dhcp snooping vlan 1
no ip dhcp snooping information option
ip dhcp snooping
interface Ethernet0/0
ip dhcp snooping trust
interface Ethernet0/1
ip verify source
interface Ethernet0/2
ip verify source
Please help me.
Thank you!!
Martin L
it does not work even with manual host binding
 ip source binding xyz
! example
ip source binding AABB.CC03.7000 vlan 2000 10.3.100.112 interface Fa0/0
while
ip dhcp snooping vlan 2000
snooping works fine;  IP source verify creates dynamic port ACL to filter traffic - that could be the issue. it must be virtual image incapability.
Regards, ML
**Please Rate All Helpful Responses **
5 Replies 5
Martin L
what is this name of IOS image / version and is it implemented in this virtual IOS ?
Regards, ML
Hello Martin,
I use IOL in EVE-NG. This is show version of it.
Cisco IOS Software, Linux Software (I86BI_LINUXL2-ADVENTERPRISEK9-M), Version 15.2(CML_NIGHTLY_20190423)FLO_DSGS7, EARLY DEPLOYMENT DEVELOPMENT BUILD, synced to V152_6_0_81_E
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Tue 23-Apr-19 02:38 by mmen
ROM: Bootstrap program is Linux
SW_L2 uptime is 51 minutes
System returned to ROM by reload at 0
System image file is "unix:/opt/unetlab/addons/iol/bin/i86bi_Linux-L2-Adventerprisek9-ms.SS"
Last reload reason: Unknown reason
i could not verify if this image supports IP source guard; will try later today as I think I have the same image; Does CML has newer version of L2/L3 switch image?  Note "Iron " image name keyword is missing which is a must have IOL image for proper L3 switching.
Regards, ML
Hello
I believe Eve-ng/Virl images dont support IPSG and  you require a EMI image (Enhanced Multilayer Software) for it to work correctly.
Kind Regards
Paul
Martin L
! example
while
Regards, ML
