IPLC configuration
Can anyone help me how to configure a router for an IPLC connection.
desai.jaideep
Level 5
Level 5
An IPLC link is an point-to-point link between offices gegrophaically seperated by country borders.Here you do not have specific hardware requirements except the routers and modems.
Generally the modems are delivered by the carrier itself.The carrier will give you physical layer connectivity between both your locations.Or even it may give you frame-relay type connectivity.All you have to do is identify such carrier in your country.
I want to know:
(1)Where are the 2 locations.
(2)What is the bandwidth you are looking at.
Other economical and viable solution is :you take bandwidth from local ISP( say 2mb or so) and deploy Cisco PIX VPN on both sides.
Pls revert back if u have more questions.
Pls rate helpful posts
JD
