%IPRT-3-PATHIDX
Hi, In my 3750  switch (two in stack), I am seeing the below message: %IPRT-3-PATHIDX: Bad path pointer of 0 for 0.0.0.0, 1 max -Process= "Net Background", ipl= 0, pid= 31 -Traceback= D79168 D798B4 11BD0A4 11C29E8 11C0B98 11BC558 1043D9C 158AAB8 158AE0C 158B150 2CA0FC 2CA398 9BBFD4 9B2BCC Can anyone suggest about this problem. Thanks,
nkarpysh
Seems to be this defect:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCsd73245
Check your IOS version if within fixed - if not than vulnerable.
In general it seems to be cosmetic issue.
Nik
HTH,
Niko
nkarpysh
Nik
HTH,
Niko
Thanks.
