IPSec ACTIVE but no traffic
alinazim
Hello Everyone!
After a lot a efforts and searches, i didn't found a solution for my problem, please any one can help ?
I have a Cisco Router 4300 Series and a Sophos XG, i wanted to connect both through IPSec, i followed some tutorials and i was able to establish an IPSec connection successfully but no traffic is passing, tried ping, trace route.....
Thanks in advance !
Here is the Cisco Config:
Building configuration...
Current configuration : 3124 bytes
! Last configuration change at 15:19:34 UTC Mon Dec 20 2021 by cisco
version 15.5
no platform punt-keepalive disable-kernel-core
hostname ROUTER_1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 XXX
enable password XXX
aaa new-model
aaa authentication login default local
aaa session-id common
ip dhcp excluded-address 192.168.6.208
ip dhcp excluded-address 192.168.6.205
ip dhcp excluded-address 192.168.6.201
ip dhcp pool LAN_DHCP
 network 192.168.6.0 255.255.255.0
 default-router 192.168.6.254
 dns-server 8.8.8.8 8.8.4.4
subscriber templating
redundancy
 mode none
vlan internal allocation policy ascending
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key XXXXX address 172.105.223.23
crypto ipsec transform-set Sophos_Main esp-3des esp-md5-hmac
 mode transport
crypto ipsec profile Sophos_Main
 set security-association lifetime seconds 86400
 set transform-set Sophos_Main
crypto map VPN_To_Main 10 ipsec-isakmp
 ! Incomplete
 set peer 172.105.223.23
 ! access-list has not been configured yet
 set pfs group2
 match address 101
interface Tunnel10
no ip address
 tunnel source Dialer1
 tunnel mode ipsec ipv4
 tunnel destination 172.105.223.23
 tunnel protection ipsec profile Sophos_Main
interface GigabitEthernet0/0/0
 description " TO WAN AT "
 no ip address
 negotiation auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface GigabitEthernet0/0/1
 description " To LAN NETWORK "
 ip address 192.168.6.254 255.255.255.0
 ip nat inside
 negotiation auto
interface Dialer1
 ip address negotiated
 ip mtu 1460
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 800
 dialer pool 1
 ppp authentication chap callin
 ppp chap hostname XXXXXXX
 ppp chap password 0 XXXXXXXX
 ppp ipcp dns request
 ppp ipcp route default
ip default-gateway 192.168.6.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.1.0 255.255.255.0 Dialer1
ip route 192.168.1.0 255.255.255.0 172.105.223.23
control-plane
line con 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
end
try the crypto map again, with the suggested changed on the Sophos: in the 'Phase 2' settings, under 'PFS Group', set that to 'Same as Phase 1', and in the 'Gateway type' settings, drop down, selecht 'Initiate the connection'..
version 15.5
hostname ROUTER_1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 XXX
enable password XXX
aaa new-model
ip dhcp excluded-address 192.168.6.254
redundancy
mode none
encr 3des
hash md5
group 2
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 10 3
mode transport
set pfs group2
match address 101
no ip address
negotiation auto
ip nat inside
negotiation auto
interface Dialer 1
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no ip http server
ip dns server
ip route 0.0.0.0 0.0.0.0 Dialer 1
ip nat inside source list 102 interface Dialer 1 overload
access-list 101 permit ip 192.168.6.0 0.0.0.255 ip_subnet_other_end
access-list 102 deny ip 192.168.6.0 0.0.0.255 ip_subnet_other_end
access-list 102 permit ip 192.168.6.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
end
14 Replies 14
Seb Rupik
Hi there,
You have specified the ACL '101' in the crypto map but have not specified what the ACL is in the running config. The ACL needs to match the traffic which you want to send via the IPSec tunnel as it egresses the Dialer1 interface. The remote VPN endpoint will need the mirror version of this ACL so that return traffic is send via the IPsec tunnel.
cheers,
Seb.
Hello !
Thanks for the answer ! i will check that.
Cheers.
Did you got the good answer please mention me there or what method you use. Kindly help me out.
Hello !
Used Georg Pauwen's answer and it works perfectly, i have marked the answer as solution.
Cheers.
I don't think the Sophos does VTIs, so you need to use crypto maps. The config below should work (if the other end has the same parameters). Don't use group 2, which is considered unsafe. I have replaced that with group 5. Make sure the config looks exactly like this one, line by line. When you are done, post the finished config again, so we can double check:
version 15.5
hostname ROUTER_1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 XXX
enable password XXX
aaa new-model
redundancy
mode none
encr 3des
hash md5
group 5
mode transport
set pfs group2
match address 101
no ip address
negotiation auto
ip nat inside
negotiation auto
interface Dialer 1
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
no ip http server
ip dns server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
end
Hello !
Thanks for the answer, i tried exactly your solution but it still doesn't work, the tunnel is not connecting at all whereas with the initial config the IPSec connects but no traffic.
You didn't specify the Tunnel interface in the config you provided, was it intentional ?
Thanks in advance.
Cheers.
since there is no information on the Sophos config, it can be either crypto map or VTI. Crypto map apparently does not work, so try the config below:
version 15.5
hostname ROUTER_1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 XXX
enable password XXX
aaa new-model
redundancy
mode none
encr 3des
hash md5
group 2
mode transport
interface Tunnel10
no ip address
no ip address
negotiation auto
ip nat inside
negotiation auto
interface Dialer1
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no ip http server
ip dns server
ip route 192.168.1.0 255.255.255.0 Tunnel10
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.6.0 0.0.0.255
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
end
Hi There !
Thanks for the answer, i tried the config, the Tunnel state turned up in both the Cisco and Sophos but when i try to ping still no traffic.
The weird thing is when i do a traceroute here is what i get:
From a host in the Sophos network (192.168.1.0/24) to a host in the Cisco network (192.168.6.0/24):
traceroute to 192.168.6.1 (192.168.6.1), 64 hops max, 52 byte packets
 1  192.168.0.1 (192.168.0.1)  15.211 ms  2.006 ms  3.662 ms
 2  192.168.1.254 (192.168.1.254)  3.156 ms  4.044 ms  2.345 ms
 3  * * *
 4  * * *
 5 same and never ends...
From a host in the Cisco network (192.168.6.0/24) to a host in the Sophos network (192.168.1.0/24):
traceroute to 192.168.1.220 (192.168.1.220), 64 hops max, 52 byte packets
 1  192.168.6.254 (192.168.6.254)  0.661 ms  0.634 ms  0.561 ms
 2  172.105.0.23 (172.105.0.23)  20.910 ms  13.597 ms  20.649 ms
 3  10.109.36.95 (10.109.36.95)  13.050 ms  13.234 ms  13.299 ms
 4  * * *
 5  It shows other IPs....
It seems like the Sophos routes correctly packages to the Cisco and waiting for a response forever, whereas the Cisco routes packages directly to the Internet and then.... never come back.
The Sophos Config screenshots are attached below.
Thanks in advance.
Cheers.
I am still not sure the Sophos works with the VTI. Either way, on the Sophos, in the 'Phase 2' settings, under 'PFS Group', set that to 'Same as Phase 1', and in the 'Gateway type' settings, drop down, selecht 'Initiate the connection'...
Hi There,
Same thing, this time the Tunnel keeps dropping connection and when it's up, no pings.
Thanks.
Cheers.
version 15.5
hostname ROUTER_1
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 XXX
enable password XXX
aaa new-model
redundancy
mode none
encr 3des
hash md5
group 2
mode transport
set pfs group2
match address 101
no ip address
negotiation auto
ip nat inside
negotiation auto
interface Dialer 1
ip mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no ip http server
ip dns server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
end
And if it still not works, post the output of:
debug crypto ipsec
debug crypto isakmp
Hello !
It perfectly works, Thanks !
Cheers.
Hi friend,
why you config two IPSec one under dialer and other under tunnel?
