conf t not working on Cisco ISR 4221
feindouno_emile
I have this problem on cisco isr 4221, i can not do configure terminal.
Can someone help me to fix this issue?
Router>en
*Apr 14 10:02:04.529: %SEC_LOGIN-5-LOGIN_SUCCESS: Login Success [user: admin] [Source: LOCAL] [localport: 0] at 10:02:04 UTC Wed Apr 14 2021
Router#conf t
This command is not supported
Router#
Yes the router is running SD-WAN firmware.
I fix the issue by typing this command
Router#
controller-mode disable
5 Replies 5
Mark Elsen
        - Examine the privilege level of this current user.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
the privilege level is 15
Leo Laohoo
@feindouno_emile wrote:
Router#conf t
Router#
Router is running SD-WAN firmware.
Router#
Bilelo-90
Hi @feindouno_emile
I think you need also to change the IOS, because it is an image for SDWAN installed
In my case I installed the
isr4200-universalk9_ias.16.12.05.SPA
Kind regards
