IPSEC Config on IOS Router
CiscoBrownBelt
Level 6
Level 6
So I am trying to t-shoot a IPSEC tunnel issue (goes down every now and then) between an ASA and Router. One thing when looking at remote side of router I notice Group numbers don't match such as under the ikev2 proposal config and then under the crypto map config. Don't they both have to be the same? See configs below (had to scrub do to security) in case something seems pretty off, maybe I did not make changes match.
Does anyone see anything incorrect?
crypto ikev2 proposal ikev2-TEST-prop
 encryption aes-cbc-256
 integrity sha384
 group 22
crypto ikev2 policy ikev2-TEST-pol
 match fvrf TEST_vrf
 match address local X.X.X.247
crypto ikev2 keyring TEST_Keyring
 peer inscom
  description TEST
  address X.X.X.37
  pre-shared-key local <pre-shared-key removed>
  pre-shared-key remote <pre-shared-key removed>
crypto ikev2 profile X.X.X.ikev2-prof
 description TEST profile
 match fvrf TEST
 match identity remote address X.X.X.37 255.255.255.255
 authentication local pre-share
 authentication remote pre-share
 keyring local TEST_Keyring
 dpd 10 2 on-demand
 ivrf TEST_vrf
crypto ipsec transform-set TEST_transform-aes esp-aes 256 esp-sha-hmac
 mode tunnel
crypto map TEST_map local-address Loopback311
crypto map TEST_map 10 ipsec-isakmp
 description TEST
 set peer X.X.X.37
 set transform-set TEST-transform-aes
 set pfs group15
 set ikev2-profile TEST-ikev2-prof
 match address TEST_ACL
ip route vrf TEST_vrf 0.0.0.0 0.0.0.0 GigabitEthernet1/0/1.79 X.X.X.10
ip access-list extended TEST_ACL
 permit ip X.X.X.113.0 0.0.0.64 any
interface GigabitEthernet1/0/1.2978
 encapsulation dot1Q 79
 ip vrf forwarding TEST
 ip address X.X.X.14 255.255.255.248
 crypto map TEST_map
interface GigabitEthernet1/0/0.52
 encapsulation dot1Q 251
 ip vrf forwarding TEST_vrf
 ip address X.X.X.6 255.255.255.248
 ip mtu 1376
 ip tcp adjust-mss 1336
interface Loopback311
 description TEST loopback
 ip address X.X.X.246 255.255.255.255
10 Replies 10
Yes the group's do need to match on both peer devices for the ikev2 proposal and the pfs group under the crypto map. If they do not match the tunnel will not come up.
EDIT: To clarify my above comment, which after re-reading may not be clear. The IKEv2 Proposal DH group on both devices (ASA and Router) must be the same in order for IKEv2 SA to be established. The PFS group must be the same on both devices (ASA and router) for PFS to work. The IKEv2 Proposal and PFS Group could be different as long as the peer device is configured the same....but you are unlikely to configure different groups, because why would you want to use a potentially weaker cipher. I use this Cisco post to identify which algorithms to use, DH groups 19, 14 and 21 are preferred (by cisco) nowadays.
try and change the DH and PFS groups as below (marked in bold). The ASA groups need to match, obviously.
Also, to be sure, check the NTP settings on both devices and make sure the clocks match...
If possible, post the ASA config as well...
integrity sha384
group 5 2 14
match fvrf TEST_vrf
peer inscom
description TEST
address X.X.X.37
match fvrf TEST
dpd 10 2 on-demand
ivrf TEST_vrf
mode tunnel
description TEST
set peer X.X.X.37
set pfs group2
crypto map TEST_map
ip mtu 1376
Deepak Kumar
Ikev2 is giving you the flexibility to add multiple parameters as a group under the single proposal. As below:
 integrity sha384
 group 22 14 12
This is not compulsory having Phase1 DH group and PF group to be the same.  Both are having different aim and purpose in the configuration. But both configuration must be some devices.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
just like to add- Thr problem doesn’t seem the establishment of the isakmp-IPSec sa’s it’s sounds like an intermittent issue correct?
Areyou sure this isnt a physical issue regards the connectivity between the asa and rtr ?
That said possibly suggest to check also any IPSec idle timeout values being set or not
Kind Regards
Paul
I am not positive there is no physical issue, I don't handle the remote router but I can only assume these type of things have been checked. One thing to note is that when connection goes down, I am able to get it back up by simply refreshing/bouncing the connection.
Should I be making sure idle-timeouts are set the same if they are set?
As you say that "I am able to get it back up by simply refreshing/bouncing the connection."
Then I am assuming that there is DPD or Phase1 timer (lifetime) mismatch error. Have you verified that same? Phase1 lifetime must be higher than Phase 2.
Deepak Kumar
Deepak Kumar,
 I can see lifetime values ( sa timing: remaining key lifetime (kB/sec): (1519895/23928) from sh crypto ipsec sa
and
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
from sh running-config all | include crypto
This output does not specify which tunnel this applies to so I assume it is globally applied to all?
When I look at "Session Details" from ASMD, I see Rekey Time Interval: 86400 seconds for IKEv2
and 28800 for IPSEC this is it correct?
Also I don't see how to verify DPD on ASA if it is supported? Having difficulty looking this up.
The below output is what I have as well.
ASA#sh running-config all | include isakmp
object service udp-isakmp pre-defined
 service udp destination eq isakmp
 service-object udp destination eq isakmp
crypto isakmp identity address
crypto isakmp nat-traversal 10
 isakmp keepalive threshold 10 retry 2
 isakmp keepalive threshold 300 retry 2
 isakmp keepalive threshold 3600 retry 2
and
ASA# sh running-config all | include ipsec
Why that much DPD configurations?
Deepak Kumar
Deepak Kumar,
Good question I don't know. There are multiple IPSEC VPNs on this ASA, however there should only be 1 "isakmp keepalive threshold X retry X" statement and " service-object udp destination eq isakmp" statement correct?
Only on DPD configuration is required for any number of VPN connections. But I am not sure where and why are you using "service-object udp destination eq isakmp" statement? I have to look at your configuration before guide you.
Deepak Kumar
Deepak Kumar,
