IPsec-NAT , Port UDP4500 and 500.
eng_adel273
Dear Sir
The attached router configuration block port UDP4500 and 500.
Please check it and send your response
43 Replies 43
Thank you for your support
Please check the attached file about the remote IPs
The entries you have highlighted are related to each other.  However all of the configuration you have given is for user to site VPNs, not site to site VPNs.
Thank you for your reply , how can we make it site-to-site VPNs
Can you help me to setup the site-to-site VPN
Alright, using only the Cisco routers;
On the 192.168.10.1 router:
crypto keyring kr-site-to-site
  pre-shared-key address 78.93.247.181 key 0123456789
crypto isakmp profile ikev1-site-to-site
  match identity address 78.93.247.181 255.255.255.255
crypto ipsec profile ipsec-profile
  set transform-set ESP-3DES-SHA
  set isakmp-profile ikev1-site-to-site
interface Tunnel 0
  ip address 192.168.255.1 255.255.255.252
  tunnel source 78.93.216.19
  tunnel destination 78.93.247.181
  tunnel protection ipsec profile ipsec-profile
ip route 192.168.20.0  255.255.255.0 Tunnel0
On the 192.168.20.1 router:
  pre-shared-key address 78.93.216.19 key 0123456789
  match identity address 78.93.216.19 255.255.255.255
interface Tunnel 0
  ip address 192.168.255.2 255.255.255.252
  tunnel source 78.93.247.181
  tunnel destination 78.93.216.19
ip route 192.168.10.0 255.255.255.0 Tunnel0
Dear Philip
Thank you for your support , I attached a file contains some question please check it
Thank you for your efforts and cooperation
Because we are using seperate Tunnel interfaces, and they don't have "ip nat" configured on them, the router wont apply NAT to this traffic.
Can you get rid of the Cyberoam boxes, they do complicate the solution a bit.  Otherwise just add more static routes through the tunnels to get to the remote networks, and make sure the Cyberoam boxes allow the traffic through and don't NAT it.
 is it necessary to make ip route for remote LAN on the both router or just your ip route is enough?
Both routers need an "ip route" for each remote network that is to go over the VPN.
Dear Philip
I have router 1841 , when I enter a crypto line into config t i get an error.
crypto % Invalid input detected at '^' marker
waiting for your feedback
You did this is config mode right?
Yes , within the Config Mode
also
crypto keyring
Hmm, maybe you are running an older IOS.  What model Cisco routers are you using and what software version are they running?
Do they take the other crypto commands ok?
router 1841
We are going to have to use an older way of doing this.  On the 192.168.10.1 router try:
crypto isakmp key 0123456789 address 78.93.247.181 no-xauth
interface Tunnel 0
