Failed to add port channel on Cisco indestrial Switch
PLease Can any Body help me !!!
% Command Rejected: Remove ACL configured on member port
GigabitEthernet1/1 is not added to port channel
marce1000
           - Check/show-us  the running-config of this port first.
 M.
I would default the member ports and try again:
Switch(config)#default interface x --> do that for all member ports
Hello
If this is a production PC then I wouldn’t suggest you default any physical interfaces that are part of the etherchannel, you should in theory be able just to add an additional physical interface to a existing PC unless its not configuration the same as the other members ports.
So make sure the physical interface your adding has parity with the other PC members in terms of configuration.
Kind Regards
Paul
