03-04-2007 03:14 PM - edited 03-03-2019 04:01 PM
I am having some issues with a VPN setup between an 1841 and 7206. The setup on the 1841 side is as follows;
1 x ADSL WIC
2 x F/E
Remote VPN Range 1: 10.77.0.0/21
Remote VPN Range 2: 10.116.0.0/16
Dialer0 - Public IP with /32 (NAT outside)
FE0/0 - 192.168.1.1/255.255.255.0 (NAT inside)
FE0/1 - Public IP with /28
crypto ipsec transform-set MYTRANS esp-3des esp-md5-hmac
crypto map MYMAP 10 ipsec-isakmp
set peer 203.20.x.x
set transform-set MYTRANS
match address 100
crypto map MYMAP 11 ipsec-isakmp
set peer 203.20.x.x
match address 101
int Dialer0
crypto map MYMAP
access-list 100 permit ip 192.168.1.0 0.0.0.255 10.77.0.0 0.0.0.7.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 10.116.0.0 0.0.255.255
This setup is working ok apart from a few small issues. The tunnel to the VPN will only initiate properly when a ping is made from either 10.77.0.0/21 or 10.116.0.0/16 to the IP 192.168.1.1. After the VPN establishes, I can then ping the devices on the remote network. However, if I just ping anything on the 10.77.0.0 or 10.116.0.0 network, the VPN will not establish.
I have tried playing around with route-map commands and changing details of the ACLs to deny but still cannot get this working :(
Can post full config if needed
03-05-2007 07:25 PM
Good to see i'm not the only one who is scratching my head. I wouldn't call myself an expert in Cisco equipment, but I do pretty well finding my way around it all :)
Here is the config;
sh run
Building configuration...
Current configuration : 5196 bytes
version 12.4
hostname ax-gw-01
boot-start-marker
boot-end-marker
logging buffered 52000 debugging
no aaa new-model
resource policy
ip cef
ip domain name axent.com.au
ip name-server 139.130.4.5
ip name-server 203.14.168.3
! crypto pki trustpoint REMOVED FOR POSTING
! crypto pki certificate chain REMOVED FOR POSTING
! username REMOVED FOR POSTING
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key xxxxxxxxxxxx address 203.20.xx.xxx
crypto ipsec transform-set vodafone esp-3des esp-md5-hmac
crypto map vodafone-apn ipsec-isakmp
description Vodafone APN Network
set peer 203.20.xx.xxx
set transform-set vodafone
match address 100
interface FastEthernet0/0
description Axent Internal Network
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
duplex auto
speed auto
interface FastEthernet0/1
description Axent Public Network
ip address 203.206.xxx.xxx 255.255.255.240
duplex auto
speed auto
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
dsl operating-mode ansi-dmt
interface ATM0/1/0.1 point-to-point
description iiNet ADSL2 Network
no snmp trap link-status
pvc 8/35
pppoe-client dial-pool-number 1
interface Async0/0/0
no ip address
encapsulation slip
interface Dialer0
ip address 203.206.xxx.xxx 255.255.255.254
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username adslusername password xxxxxxxx
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http access-class 2
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
! NOTE - SOME ACLS REMOVED FOR POSTING
access-list 100 permit ip 192.168.1.0 0.0.0.255 10.77.0.0 0.0.7.255
access-list 100 permit ip 192.168.1.0 0.0.0.255 10.116.0.0 0.0.255.255
dialer-list 1 protocol ip permit
route-map vodafone permit 1
match ip address 100
control-plane
! banner login REMOVED FOR POSTING
line con 0
login local
line aux 0
line 0/0/0
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
access-class 30 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 30 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp clock-period 17178100
ntp update-calendar
ntp server 128.250.36.2 source Dialer0 prefer
end
Other things that I have also tried are;
- ACLs with deny statements as per previous posts
- Adding route-map for NAT translation
- Configured a PC at 192.168.1.2 and tried to ping from that machine. Vodafone suggested the Cisco is incapable of making the connection and that a PC on the local side would have to initiate. No avail here either.
03-05-2007 09:37 PM
you removed the translation statement as well!
I still think you will need to stop the encypted traffic being NAT'ed first, but based on the info to hand, I cannot say why it broke everything!
I say that ( after further reading) because of the lines:
Mar 5 22:56:26.070: ISAKMP:(0): constructed NAT-T vendor-07 ID
Mar 5 22:56:26.070: ISAKMP:(0): constructed NAT-T vendor-03 ID
Mar 5 22:56:26.070: ISAKMP:(0): constructed NAT-T vendor-02 ID
and that NAT-T refers to NAT Traversal, ref RFC 3947
AS you probably noted:
from the sh crypto ipsec sa file, it looks like the 1841 is suggesting a transform of Tunnel,
(key eng. msg.) OUTBOUND local= 203.206.183.117, remote= 203.20.38.100,
local_proxy= 192.168.1.0/255.255.255.0/0/0 (type=4),
remote_proxy= 10.116.0.0/255.255.0.0/0/0 (type=4),
protocol= ESP, transform= NONE (Tunnel),
lifedur= 3600s and 4608000kb,
whereas the working one negotiates;
(key eng. msg.) INBOUND local= 203.206.183.117, remote= 203.20.38.100,
protocol= ESP, transform= esp-3des esp-md5-hmac (Tunnel),
the question is why ..
and at about this time, I hope someone wlse will read this thread and say - look, there's the cause of the problem!
03-06-2007 01:53 PM
Actually, that is one thing that I hadn't noticed. After pointing that out, I made some further changes to the config by specifying an isakmp profile to match the encrytion, hash, etc. but it's still using NONE as the transform set :(
I have an 857 ADSL router that is ready to be commissioned into another branch office, so I might create a site-to-site VPN with this back to the 1841 and see whether I have the same issues. Hopefully it will point me in the right direction.
Failing everything else, is troubleshooting of this covered in the SMARTnet contract? We did order them with the routers but they are still to arrive.
03-06-2007 03:26 PM
one more ( last?) thing - can you check the NAT table when trying to ping the PDA, and it not working? And also provide sh ip nat stat output? And, can you try the acl denying the tunnel traffic, but ensuring the NAT table is cleared ( pelase provide same output) ?
WRT SmartNet - I don't know ...
03-06-2007 06:59 PM
Okay. Some outputs for perusal :)
Router reloaded and no IPSEC connected
ax-gw-01#sh ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
Virtual-Access1, Dialer0
Inside interfaces:
FastEthernet0/0
Hits: 0 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] route-map vodafone interface Dialer0 refcount 0
Queued Packets: 0
ax-gw-01#
I now have a PC behind the 192.168.1.1 interface with an IP of .2
Once the tunnel is bought up from the PDA, I can ping out to 10.77/10.116 no problems. Once I bring down the tunnel, and ping from the PC, still getting stuck at PHASE_1_COMPLETE of ISAKMP.
This proves to me now that the NAT Translation is working correctly due to the reconfigured lists as follows;
ip nat inside source route-map vodafone interface Dialer0 overload
access-list 120 deny ip 192.168.1.0 0.0.0.255 10.77.0.0 0.0.7.255
access-list 120 deny ip 192.168.1.0 0.0.0.255 10.116.0.0 0.0.255.255
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
match ip address 120
OK, now NAT Statistics. If I bring up the tunnel and ping from the PC (192.168.1.2) there are no NAT Translations in sh ip nat translations. However, they do show up when I ping a public IP address (eg. ns1.pacific.net.au)
When I ping from 192.168.1.1 I still get a zero count on the NAT statistics.
03-06-2007 08:39 PM
clutching at straws ...
the line
has usually a seq number in it ...
e.g.
crypto map vodafone-apn 1 ipsec-isakmp
states that it should not be arbitrary.
03-06-2007 09:38 PM
Unfortunately that must have been my clumsy editing whilst taking out other info because it is in the config :(
I'm going to try and setup another VPN in the meantime with the 857 that we have running at another branch. Vodafone has finally asked for a copy of the config and are also looking into it.
If anyone else is looking at these posts as well, please see if we have missed something so trivial
03-14-2007 03:33 AM
I tried with similar configuration that you were using in my lab (with physical interfaces) and it is working correctly.
Seems the problem is not with NAT but with virtual interface (dialer) interface.
I think you need to configure crypto map both on dialer interface and the physical interface.
Check the below link for more details.
http://cco/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e52.shtml
Config I took from your mail,
PS:- NAT will not be applied to the traffic between 192.168.1.2 and (10.77.0.0 or 10.116.0.0) as per the above ACLs.
HTH,
Radhika
03-14-2007 03:50 AM
Hi Radhika,
I tried applying the crypto maps to both the ATM0/1/0.1 interface as well as the Dialer0 interface and still getting no further than PHASE 1 completing.
Can you shed some more light also on the NAT ACLs?
Cheers,
Andrew
03-14-2007 04:10 AM
Attaching the information of cli configuired on both the routers. Please check if it can give you any information.
NAT router
ip nat inside source route-map vodofone interface Serial0 overload
route-map vodofone permit 1
match ip address natTest
! ip of loopback102 interface to ip of remote router's ethernet0 interface - denied - no nat done for the traffic
ip access-list extended natTest
deny ip host 10.x.x.x 18.y.y.y 0.0.0.255
permit ip host 10.x.x.x any
vpn interface :- serial0
nat outside
ip address 10.a.a.a 255.255.255.252
crypto map enabled
interface fastethernet0
nat inside
inside interface :- loopback102
ip address 10.x.x.x 255.255.255.252
! ACL used in ipsec
ip access-list extended CSM_IPSEC_ACL_1
permit ip host 10.x.x.x 18.y.y.y 0.0.0.255
! tranform set
crypto ipsec transform-set CSM_TS_1 esp-3des esp-sha-hmac
! crypto map applied on serial0 interface
crypto map CSM_CME_Serial0 1 ipsec-isakmp
description Provisioned by CSM: Peer device = 10.y.y.y
set peer 10.y.y.y
set transform-set CSM_TS_1
match address CSM_IPSEC_ACL_1
reverse-route
! preshared key
crypto isakmp key test address 10.y.y.y no-xauth
Remote Router
vpn interface :- Ethernet1
ip address 10.y.y.y 255.255.255.252
crypto map CSM_CME_Ethernet1
inside interface:- Ethernet0
ip address 18.y.y.y 255.255.255.0
! crypto map
crypto map CSM_CME_Ethernet1 1 ipsec-isakmp
description Provisioned by CSM: Peer device = 10.a.a.a
set peer 10.a.a.a
reverse-route
! tranform set
! access-list used on crypto maps
permit ip 18.y.y.y 0.0.0.255 host 10.x.x.x
! isakmp policy - same on both devices
crypto isakmp policy 5
encr 3des
group 5
! key
crypto isakmp key test address 10.a.a.a no-xauth
Radhika
03-11-2007 06:28 PM
I had the same type of problem, I got it working with:
crypto map s2s 1 ipsec-isakmp
description Tunnel to1.2.3.4
set peer 1.2.3.4
set transform-set s2s
match address 100
ip nat inside source list 121 pool wan overload
access-list 100 permit ip 172.16.100.0 0.0.0.255 4.3.2.0 0.0.0.255
access-list 121 deny ip 172.16.100.0 0.0.0.255 4.3.2.0 0.0.0.255
access-list 121 permit ip 172.16.100.0 0.0.0.255 any
access-list 121 permit ip 172.16.101.0 0.0.0.255 any
Where:
1.2.3.4 = vpn peer
4.3.2.0/25 = destination network
Using:
Cisco 871
The Crypto map is applied to di0, which is unnumbered to vlan1 (public ip space)
Nat is being done between di0 (out) and vlan2 (in) (172.16.100/24 network)
Hope this helps.
03-13-2007 09:32 PM
Hi Peter,
I tried replacing the NAT route-map with the IP nat source list instead, but still to no avail.
As previously mentioned, it seems strange that if I initiate the connection from the remote network(s) that the tunnel is successfully triggered but yet, when I initiate the tunnel from my end, it won't get past PHASE 1
Cisco now have an open TAC case but Vodafone won't even send them the debug logs that cisco want to see....Grrrrrr
The battle continues
03-26-2007 06:13 PM
Finally I have hit the money!
It has taken on of the Cisco TAC Engineers to coax Vodafone into providing the configuration to Cisco and we picked up straight away that Vodafone have specified PFS Group2 in the IPSEC Phase when our paperwork supplied by Vodafone indicated to use No PFS!!!!
No matter how many times they looked over the configuration they kept saying it was my issue.
I'm glad to get to the bottom of this and hope that others can read the topic and have it be of some use
Lesson Learnt: NEVER trust the paperwork and ask your provider to go through configuration details step by step
03-26-2007 06:17 PM
thanks for letting us know the outcome!
