L2/L3 Switch
rodneygilliard
Hi, can someone recommend for me a low cost 24-port fast-ethernet cisco switch that has L2 and L3 functionality for creating VLANs and routing internally between VLANs and routing externally.
Thanks in advance.
Absolutely. Note, some features are only in "IP services" or better image. But L3 and basic routing are in all images.
Hope this helps, please rate all useful posts!
ankbhasi
Hi Friend,
Because you asked for a single switch which can work as L2 and L3 both, the starting siwtch model will be 3560
Have a look at this link
http://www.cisco.com/en/US/products/hw/switches/ps5528/index.html
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_data_sheet09186a00801f3d7d.html
But incase you just want a basic l2 feature the lowest model will be CE500 switch
http://www.cisco.com/en/US/products/ps6545/index.html
Ankur
*Pls rate all helpfull post
Thank you.
It would be a good idea to compare IPBASE and IPSERVICES to make sure you won't need something down the road. For example, multicast routing is not supported in IPBASE.
