IPSec over GRE vs GRE over IPSec
UCrypto
Dear All,
May I know pros and cons for two type of VPN for data connectivity. if we want to carry video streaming over VPN , which one is the best solution without pixelated ?
Philip D'Ath
People only do GRE over IPSec.  GRE provides the system with something that looks like a routable interface.
You would just use IPSEC, and not IPSEC over GRE.  IPSEC over GRE would gain you nothing (compared to just IPSec) and add extra processing and overhead.
7 Replies 7
Philip D'Ath
Hi Philip D'Ath,
Thanks ,I would like to know which one can get good quality video stream between GRE over IPSec and IPSec only ?
IPSec only will have the least overhead.
Hi Philip D'Ath,
May i know if i use IPSec ,what is the best practice of tunnel MTU size ? If i use IPsec encryption with ESP-AES-256, it will take 73 bytes . 20 for IP Header . So 1500 -73=1427 - 20 = 1407 . Do we need to set MTU 1400 ? Am i Right?
I'd go with 1400 as you have suggested.
We need to secured connectivity and want to carry video traffic only. video traffic are unicast traffic and using RTSP protocol .our bandwidth is 100 M .May i know if i have 10 VPN link and i would like to know packet loss of only one VPN link ,can i check in router ? how can i see which traffic is drop and with traffic is passed ?
VPNs don't usually do so well with packet loss. If it gets to bad you'll sell the VPN flapping up and down.
