IPsec phase 1
bjornarsb
Level 4
Level 4
We try to establish an ipsec connection between two devices.
The cisco router says:
Sep 9 13:09:41.603 UTC: ISAKMP:(0:0:N/A:0):Checking ISAKMP transform 1 against priority 1 policy
Sep 9 13:09:41.603 UTC: ISAKMP: encryption 3DES-CBC
Sep 9 13:09:41.603 UTC: ISAKMP: hash MD5
Sep 9 13:09:41.603 UTC: ISAKMP: default group 1
Sep 9 13:09:41.603 UTC: ISAKMP: auth pre-share
Sep 9 13:09:41.603 UTC: ISAKMP: life type in seconds
Sep 9 13:09:41.603 UTC: ISAKMP: life duration (VPI) of 0x0 0x0 0x2 0x58
Sep 9 13:09:41.603 UTC: ISAKMP:(0:0:N/A:0):Hash algorithm offered does not match policy!
Sep 9 13:09:41.603 UTC: ISAKMP:(0:0:N/A:0):atts are not acceptable. Next payload is 0
Sep 9 13:09:41.603 UTC: ISAKMP:(0:0:N/A:0):Checking ISAKMP transform 1 against priority 65535 policy
Sep 9 13:09:41.607 UTC: ISAKMP:(0:0:N/A:0):Encryption algorithm offered does not match policy!
But the client device has 3 des and md5 configured:; G1+ Advanced SNA IPSec CR Router 5 157 Version 10.6.13TM
enable
assign-access-list 101
template 1 default
template 1 isakmp tdes md5
template 1 destination-address
template 1 life duration seconds 10m
template 3 default
template 3 dynamic esp tdes sha1
template 3 source-address ppp1
template 3 destination-address
template 3 life duration seconds 10m
map-template 101 3
The cisco:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
Any ideas ?
bjornarsb
5 Replies 5
Edison Ortiz
Bjornarsb,
In the log, it shows the router using default-group 1 while in the config it shows you entered group 2 under the ISAKMP policy 1.
Can you change the ISAKMP policy to group 1 and see if it agrees with the clients ?
Seeing the whole router config will help me understand better.
did'nt help.
Here is the config:
encr 3des
crypto isakmp key johadmin address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 60 periodic
crypto ipsec security-association idle-time 60
crypto ipsec transform-set dmvpnset esp-3des esp-sha-hmac
crypto dynamic-map DYNMAP 10
set transform-set dmvpnset
crypto map LABMAP 10 ipsec-isakmp dynamic DYNMAP
interface Loopback0
ip address 172.29.252.16 255.255.255.255
interface FastEthernet0/0
description ### mot rutercluster ###
ip address 172.29.251.16 255.255.255.192
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.7.16 255.255.255.0 secondary
ip address
duplex auto
speed auto
crypto map LABMAP
Bjornarsb,
You are using MD5 at the client side while on the router side MD5 is missing
encr 3des
You should have
encr 3des
hash md5
thanks !
I had it configured but not group 1
at det same time.
Good call Edison, that should correct this issue, Take care and keep up the posts
