IPSec route over MPLS
Mirko442
Hello guys,
I'm working on a project, here's the picture
Circle in the middle has MPLS configured, I've configured VRF's and managed to ping 3 sites Split, Makarska and Imotski. Next step I added internet router and configured static routes so each site can reach it. After that I configured IPSEC on the internet links so each site can reach eachother through IPSEC internet link aswell. Now when I ping pc's the traffic goes trough internet IPSEC links, and only goes trough mpls if i turn internet links off. I want primary route to be trough MPLS and only go trough IPSEC if MPLS fails.
On my CE router, those routes go trough internet link with AD 1.
Anyone has idea on how to route traffic so it goes trough MPLS first?
Giuseppe Larosa
Hello @Mirko442 ,
you need to use floating static routes over the IPSec tunnel so that they have a greater , less preferred , admin distance
use something like 220 as you AD for the floating static routes
ip route <net > 255.255.255.0 172.4.1.1 220
and so on
warning: this works if you receive the same set of prefixes over MPLS with a dynamic routing protocol like eBGP or OSPF.
If route summarization is performed on the MPLS cloud the suggested change is not enough as the most specific route is preferred regardless of admin distance
Hope to help
Giuseppe
8 Replies 8
Giuseppe Larosa
Hello @Mirko442 ,
and so on
Hope to help
Giuseppe
balaji.bandi
Since you have static Route that is taking preference as per the output, look below route preference :
https://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/8651-21.html
So you looking here MPLS as prefered and if that Failed you want to user Internet VPN link ?
If you running OSPF why not use OSPF also IPSEC tunnel  with metric to prefer path as MPLS  ?
BB
AD for MPLS is = 1
AD for static default  is = 1
so change the static AD to be = more than 1
check this solution.
if you prefer MPLS over direct connect then use PBR.
Mirko442
Hello guys, thanks for the quick replies,
@Giuseppe Larosa so I need to configure floating route on CE-ST for example:
ip route 10.30.5.0 255.255.255.0 132.4.2.2 220?
@balaji.bandi I didn't really understand your answer, I want my ping from PC1 to PC2 for example to go through MPLS and only go through IPSEC if MPLS interface is down.
i might have not clear here - what i was suggesting if you could able to run OSPF between Routers with metric you can make decision.
if you looking only static route increate the AD from 1 to XXX ( as suggested by @Giuseppe Larosa )
BB
Mirko442
Thanks for all the replies, I've managed to make it with floating routes! Quick replies, love it
glad you able to  fix, also test failure links.
My approach always use Dynamic protocol for good traffic engineering.
BB
