ACL
muos
I'm a total newbie so sorry this
I'm using Cisco Packet Tracer I'm simply trying to stop ICMP ping from a PC (192.168.3.4) to the Router 2811 (192.168.4.1)
access-list 101 deny icmp 192.168.4.3 0.0.0.0
I get Incomplete
echo if I add echo I get Invalid Input
Any help welcome
2 Accepted Solutions
balaji.bandi
If you are looking only host to host
try below :
access-list 101 deny icmp host 192.168.4.3 host 192.168.4.1 echo
Note : make sure you attached to interface to deny
example :
interface x/x
ip access-group 101 in
BB
access-list 101 permit ip 192.168.2.x 0.0.0.255 any
12 Replies 12
balaji.bandi
try below :
example :
interface x/x
BB
muos
Balaji thank you
if you use standard then you can
<source IP> <source mask>
if you use extended acl then you need
<source IP><source mask><destination IP><destination mask>
here in your ACL you use extended and use only souece IP & mask, you need destination IP & mask
To add a point to @MHM Cisco World 's info, when using numbered access lists, under 100 are standard (just source), 100 and over are extended (source and destination).  As you were using ACL number 101, this is why you keep getting an "incomplete" error.
Also, similar requirement if using named ACLs, i.e. standard named ACLs only have source, extended named ACLs have source and destination.
BTW, are you familiar with "?" when entering IOS commands?
How very helpful, Joseph thank you very much
muos
sorry for being so lame
Then what I read if I don't add a permit I can't ping from other devices because of an explicit deny Cisco ISO added at the end of the ACL.
I've tried
access-list 101 permit ip 192.168.4.1 0.0.0.255 any ............................
no joy, sorry guy where I'm I going wrong
what the direction you apply this ACL ??
muos
I want to block ICMP from 192.168.4.3 (PC) in to the Router on f0/0 which works
I have another network 192.168.2.x and when I ping the router it also fails... I hope that makes sense
<<- but I see 192.168.4.1 instead of 192.168.2.x
muos
it works sir! thank you is a global setting to allow all regardless of the IP range?
muos
That should read "is there a global
