IPSEC Tunnel Fails 2x2921 - Please Help
I tried putting a routing statement but no change.  NO PRIVATE INFO: I'll change the crypto key once I get this working.
ip route 192.168.175.0 255.255.255.0 192.168.176.1
ip route 192.168.176.0 255.255.255.0 192.168.175.1
!!!@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ SITE 1 @@@@@@@@@@@@@@@@@@@@@@@@!!!!
localrtr#sh run
hostname localrtr
boot-start-marker
boot-end-marker
enable secret 5 $1$A3Kg$TZeqZI6QF3r.S4nu80fZJ1
no aaa new-model
ip domain name mydomain.com
ip cef
username cisco privilege 0 password 7 05190900355E41060D
crypto isakmp policy 1
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key firewallcx address 192.168.168.236
crypto ipsec transform-set TS esp-3des esp-md5-hmac
crypto map CMAP 10 ipsec-isakmp
 set peer 192.168.168.236
 set transform-set TS
 match address VPN_TRAFFIC
interface GigabitEthernet0/0
 description OUTSIDE
 ip address 192.168.168.235 255.255.255.0
 duplex auto
 speed auto
 crypto map CMAP
interface GigabitEthernet0/1
 description INSIDE
 ip address 192.168.175.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0/0
 description MGNT_10_10_10_15
 switchport access vlan 200
 no ip address
interface Vlan200
 ip address 10.10.10.15 255.255.255.224
ip access-list extended VPN_TRAFFIC
 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
control-plane
line con 0
line vty 0 4
 login local
 transport input ssh
end
localrtr#ping 192.168.176.1 so gi0/1
Sending 5, 100-byte ICMP Echos to 192.168.176.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.175.1
Success rate is 0 percent (0/5)
localrtr#
localrtr#ping 192.168.168.236
Sending 5, 100-byte ICMP Echos to 192.168.168.236, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/1/1 ms
localrtr#
localrtr# debug crypto cond peer ipv4 192.168.176.1
localrtr# debug crypto ipsec
localrtr# debug crypto isakmp
localrtr# term mon
localrtr# sh cry isa pol
Global IKE policy
Protection suite of priority 1
    encryption algorithm:    Three key triple DES
    hash algorithm:        Message Digest 5
    authentication method:    Pre-Shared Key
    Diffie-Hellman group:    #2 (1024 bit)
    lifetime:        86400 seconds, no volume limit
localrtr#
localrtr#sh crypto map
Crypto Map IPv4 "CMAP" 10 ipsec-isakmp
    Peer = 192.168.168.236
    Extended IP access list VPN_TRAFFIC
        access-list VPN_TRAFFIC permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
    Current peer: 192.168.168.236
    Security association lifetime: 4608000 kilobytes/3600 seconds
    Responder-Only (Y/N): N
    PFS (Y/N): N
    Transform sets={
        TS:  { esp-3des esp-md5-hmac  } ,
    Interfaces using crypto map CMAP:
        GigabitEthernet0/0
localrtr#
localrtr#sh crypto session
Crypto session current status
Interface: GigabitEthernet0/0
Session status: DOWN
Peer: 192.168.168.236 port 500 localrtr#sh crypto session
  IPSEC FLOW: permit ip 192.168.175.0/255.255.255.0 192.168.176.0/255.255.255.0
        Active SAs: 0, origin: crypto map
localrtr#
Dec 14 17:43:46.005: No peer struct to get peer description
localrtr#
!!!@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ SITE 2 @@@@@@@@@@@@@@@@@@@@@@@@@!!!!
remotertr#sh run
hostname remotertr
boot-start-marker
boot-end-marker
enable secret 5 $1$m3qS$tiNd8YH.rmhKzGoRqa2970
no aaa new-model
username cisco privilege 0 password 7 105C061611051D0418
 encr 3des
 hash md5
 group 2
crypto isakmp key firewallcx address 192.168.168.235
 mode tunnel
 set peer 192.168.168.235
 description OUTSIDE
 ip address 192.168.168.236 255.255.255.0
 duplex auto
 speed auto
 crypto map CMAP
 description INSIDE
 ip address 192.168.176.1 255.255.255.0
 duplex auto
 speed auto
 description MNGT
 ip address 10.10.10.16 255.255.255.224
 duplex auto
 speed auto
 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
control-plane
line con 0
line vty 0 4
 login local
 transport input ssh
end
remotertr#ping 192.168.175.1 so gi0/1
Sending 5, 100-byte ICMP Echos to 192.168.175.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.176.1
remotertr#
remotertr#ping 192.168.168.235
Sending 5, 100-byte ICMP Echos to 192.168.168.235, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
remotertr#
remotertr#debug crypto cond peer ipv4 192.168.175.1
remotertr#debug crypto ipsec
remotertr#debug crypto isakmp
remotertr#term mon
remotertr#sh cry isa pol
Global IKE policy
remotertr#
remotertr#sh crypto map
    Peer = 192.168.168.235
        access-list VPN_TRAFFIC permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
    Current peer: 192.168.168.235
    PFS (Y/N): N
    Mixed-mode : Disabled
    Transform sets={
        GigabitEthernet0/0
    Interfaces using crypto map NiStTeSt1:
remotertr#
    PFS (Y/N): N
    Transform sets={
        GigabitEthernet0/0
remotertr#
remotertr#sh crypto session
Peer: 192.168.168.235 port 500
  IPSEC FLOW: permit ip 192.168.176.0/255.255.255.0 192.168.175.0/255.255.255.0
remotertr#
*Dec 14 17:18:13.423: No peer struct to get peer description
remotertr#
28 Replies 28
Let's start from the top.  I thought that is might be IOS related, so I copied both IOS's to each router and tested both.  Same results.  The tunnel will not come up until I put "any" as the CRYPTOMAP destination in the ACL. The R1 ACL shows matches but none on R2. ?????????????
-------------------------------R1---------------------------------------------
encr 3des
hash md5
group 2
lifetime 86400
mode tunnel
description OUTSIDE
crypto map CMAP
description INSIDE
System image file is "flash:c2900-universalk9-mz.SPA.154-3.M1.bin"
------------------------------R2---------------------------------------------
encr 3des
hash md5
group 2
lifetime 86400
mode tunnel
description OUTSIDE
crypto map CMAP
description INSIDE
-----------------------------TUNNEL DOWN------------------------------
localrtr#clear crypto isakmp
localrtr#clear crypto sa
remotertr#clear crypto isakmp
remotertr#clear crypto sa
localrtr#sh cry session
Session status: DOWN-NEGOTIATING
Session ID: 0
IKEv1 SA: local 192.168.168.235/500 remote 192.168.168.236/500 Inactive
localrtr#
-----------------------------pings with tunnel down--------------------------
localrtr#ping 191.168.176.1 so 192.168.175.1
Sending 5, 100-byte ICMP Echos to 191.168.176.1, timeout is 2 seconds:
remotertr#ping 191.168.175.1 so 192.168.176.1
Sending 5, 100-byte ICMP Echos to 191.168.175.1, timeout is 2 seconds:
-----------------------------TUNNEL COMING UP-------------------------------
NOW do something really weird.  Add any to the CRYTOMAP and the tunnel will come UP
localrtr(config)# ip access-list extended VPN_TRAFFIC
  20 permit ip 192.168.175.0 0.0.0.255 any
remotertr(config)# ip access-list extended VPN_TRAFFIC
 20 permit ip 192.168.176.0 0.0.0.255 any
- - - - - - - - - WEIRD - - - - - - - - -
localrtr(config)#ip access-list extended VPN_TRAFFIC
localrtr(config-ext-nacl)#20 permit ip 192.168.175.0 0.0.0.255 any
localrtr(config-ext-nacl)#do sh cry ses
Session status: UP-IDLE
Session ID: 0
IKEv1 SA: local 192.168.168.235/500 remote 192.168.168.236/500 Active
IPSEC FLOW: permit ip 192.168.175.0/255.255.255.0 0.0.0.0/0.0.0.0
remotertr#conf t
Enter configuration commands, one per line. End with CNTL/Z.
remotertr(config)#ip access-list extended VPN_TRAFFIC
remotertr(config-ext-nacl)#20 permit ip 192.168.176.0 0.0.0.255 any
remotertr(config-ext-nacl)#do sh cry ses
Session ID: 0
IKEv1 SA: local 192.168.168.236/500 remote 192.168.168.235/500 Active
IPSEC FLOW: permit ip 192.168.176.0/255.255.255.0 0.0.0.0/0.0.0.0
-------------------------------ACL MATCHEDS------------------------------
localrtr(config-ext-nacl)#do sh ip access-l
10 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255 (1516 matches)
20 permit ip 192.168.175.0 0.0.0.255 any (97 matches)
remotertr(config-ext-nacl)#do sh ip access-list
10 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255
---------------------------SH LICENSES-------------------------
R1 ------------------------------------------------------------------------
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data datak9 Permanent datak9
R2 ------------------------------------------------------------------------
-------------------------SH CRYPTO IPSEC SA----------------------------------
localrtr(config-ext-nacl)#ip access-list extended VPN_TRAFFIC
localrtr(config-ext-nacl)#no 20 permit ip 192.168.175.0 0.0.0.255 any
remotertr(config-ext-nacl)#ip access-list extended VPN_TRAFFIC
remotertr(config-ext-nacl)#no 20 permit ip 192.168.176.0 0.0.0.255 any
localrtr(config-ext-nacl)#do clear cry isa
localrtr(config-ext-nacl)#do clear cry sa
remotertr(config-ext-nacl)#do clear cry isa
remotertr(config-ext-nacl)#do clear cry sa
------------------------------SH CRY IPSEC SA--------------------------------
localrtr#sh cry ipsec sa
interface: GigabitEthernet0/0
Crypto map tag: CMAP, local addr 192.168.168.235
protected vrf: (none)
local ident (addr/mask/prot/port): (192.168.175.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.176.0/255.255.255.0/0/0)
current_peer 192.168.168.236 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 192.168.168.235, remote crypto endpt.: 192.168.168.236
plaintext mtu 1500, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0
current outbound spi: 0x0(0)
PFS (Y/N): N, DH group: none
---------------------------------R2-----------------------------
remotertr#sh cry ipsec sa
Crypto map tag: CMAP, local addr 192.168.168.236
local ident (addr/mask/prot/port): (192.168.176.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.175.0/255.255.255.0/0/0)
current_peer 192.168.168.235 port 500
local crypto endpt.: 192.168.168.236, remote crypto endpt.: 192.168.168.235
Thanks for the additional information. This is quite surprising that adding the any parameter in the acl makes the tunnel come up. Would you post the output of show crypto ipsec sa from both routers at a time that the tunnel is up (when the acl includes the any parameter).
Is it possible that address translation is configured on either (or both) routers? If so would you post that part of the configs?
Rick
Rick
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#sh run
Building configuration...
Current configuration : 2697 bytes
! Last configuration change at 16:57:27 UTC Mon Dec 17 2018 by cisco
version 15.4
service password-encryption
hostname localrtr
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.154-3.M1.bin
boot-end-marker
no aaa new-model
no ip domain lookup
ip domain name cortana.com
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
license udi pid CISCO2921/K9 sn FTX1714AKGS
hw-module pvdm 0/0
redundancy
ip ftp username ahuffman
ip ftp password 7 091D1C180E040408134D241B1C051B090D
encr 3des
hash md5
group 2
mode tunnel
interface Embedded-Service-Engine0/0
no ip address
shutdown
service-module enable
description OUTSIDE
duplex auto
speed auto
crypto map CMAP
description INSIDE
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
interface FastEthernet0/0/1
no ip address
interface FastEthernet0/0/2
no ip address
interface FastEthernet0/0/3
no ip address
interface Vlan1
no ip address
interface Vlan200
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.175.0 255.255.255.0 192.168.168.236
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input ssh
scheduler allocate 20000 1000
ntp server 192.168.168.200
end
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#sh run
Current configuration : 2302 bytes
! Last configuration change at 16:31:38 UTC Mon Dec 17 2018 by cisco
version 15.4
hostname remotertr
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
license udi pid CISCO2921/K9 sn FJC1903A25P
redundancy
ip ftp password 7 040A591718205F5411582526252A3F3E12
encr 3des
hash md5
group 2
mode tunnel
no ip address
shutdown
description OUTSIDE
duplex auto
speed auto
crypto map CMAP
description INSIDE
duplex auto
speed auto
description MNGT
duplex auto
speed auto
no ip http server
ip route 192.168.176.0 255.255.255.0 192.168.168.235
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line 2
no exec
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input ssh
end
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
remotertr#
-----------------------------------------R1-------------------------------------
    10 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255 (1032 matches)
    20 permit ip 192.168.175.0 0.0.0.255 any (313 matches)
  Session ID: 0
localrtr(config-ext-nacl)#do sh cry ipsec sa
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
   remote ident (addr/mask/prot/port): (0.0.0.0/0.0.0.0/0/0)
     PERMIT, flags={origin_is_acl,ipsec_sa_request_sent}
    #send errors 320, #recv errors 0
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
---------------------------------------------------_R2-------------------------------------------
remotertr(config)#
remotertr(config)#
remotertr(config)#
remotertr(config)#do sh ip access-l
remotertr(config)#do sh cry ses
  Session ID: 0
remotertr(config)#do sh cry ipsec sa
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
remotertr(config)#
remotertr(config)#
remotertr(config)#
remotertr(config)#
I have re-read this thread several times and have some additional comments/questions.
I see this in some output from router 2
I do not see any reference to that crypto map in the configs and assume that it was perhaps in an earlier version of the config and has been removed. I would suggest reboot of both routers to remove any lingering memory of things that have been removed from the configs.
I noticed that when you were setting up conditional debug (which is a VERY helpful tool when troubleshooting vpn) that the address you specified (which should be the peer address) was the address of the peer lan - but not the peer address (192.168.168.235/236). If you clean that up done know if debug would have helpful information.
I do not see any route statements in the configs that you posted. And in one post you suggest that the tunnels act like routing statements and so you do not need route statements. That is not the case. To clarify the issue would you post the output of show ip route from both routers?
Rick
Rick
I see that while I was re-reading and then writing my response that you posted current configs. They show that there is no address translation and that there is now routing statements for the remote subnets. So 2 of my theories are demonstrated to not be the issue.
I also see that you have posted the output of show crypto ipsec sa. What is interesting there is that while it does show that the tunnel is up it also shows that 0 packets encapsulated and 0 packets decaps. So even though the tunnel is up it is not carrying any traffic. So we have some issue to find beyond adding the any parameter  to the acl.
Rick
Rick
Richard, thanks for your help.  The tunnel just pinged !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  Your the best!
Since it is working, can I leave the other 0.0.0.0 SA?  Is it a security risk?  Should I try to remove the any from the ACL?
--------------------------------ROUTE STATEMENT-----------------------------
localrtr(config)#ip route 0.0.0.0 0.0.0.0 192.168.168.236
localrtr(config)#do sh run | i NiStTeSt1
localrtr(config)#do ping 192.168.176.1 so 192.168.175.1
Success rate is 40 percent (2/5), round-trip min/avg/max = 1/1/1 ms
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
localrtr(config)#
remotertr(config)#ip route 0.0.0.0 0.0.0.0 192.168.168.235
remotertr(config)#do sh run | i NiStTeSt1
remotertr(config)#
do ping 192.168.175.1 so 192.168.176.1
remotertr(config)#
--------------------------------ACL MATCHES-------------------------------------
localrtr(config)#do sh ip access-l
10 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255 (1765 matches)
20 permit ip 192.168.175.0 0.0.0.255 any (645 matches)
localrtr(config)#
10 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255 (12 matches)
remotertr(config)#
The 0.0.0.0 is used in the R1 ACL but not in the R2 ACL?  Is there something wrong with R1?
----------------------------------R1 ACL-----------------------------
localrtr#clear access-list counters
localrtr#ping 192.168.176.1 so 192.168.175.1
localrtr#sh ip access-
localrtr#sh ip access-lists
10 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255 (29 matches)
20 permit ip 192.168.175.0 0.0.0.255 any (9 matches)
10 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255 (44 matches)
20 permit ip 192.168.175.0 0.0.0.255 any (14 matches)
10 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255 (57 matches)
20 permit ip 192.168.175.0 0.0.0.255 any (18 matches)
10 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255 (78 matches)
20 permit ip 192.168.175.0 0.0.0.255 any (26 matches)
10 permit ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255 (355 matches)
20 permit ip 192.168.175.0 0.0.0.255 any (123 matches)
localrtr#
-----------------------------------R2 ACL--------------------------------------
emotertr#sh ip access-lists
10 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255 (37 matches)
remotertr#ping 192.168.175.1 so 192.168.176.1
remotertr#sh ip access-lists
10 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255 (42 matches)
10 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255 (47 matches)
10 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255 (52 matches)
10 permit ip 192.168.176.0 0.0.0.255 192.168.175.0 0.0.0.255 (57 matches)
remotertr#
Did some testing, it was the routing statement all the time.  I removed the "any" from the ACL and now the L2 tunnel is up and working.  Thank you Richard
I am very glad (and a bit relieved) that the problem is solved and that my suggestion pointed in the right direction. The issue with a crypto acl that uses permit any is that when applied any traffic from the source subnet going out the outside interface will be encrypted and sent through the tunnel. That would impact the ability of anything on the source subnet to access resources in the Internet.
Thank you for marking this question as solved. This will help other participants in the community to identify discussions that have helpful information. This has been an extensive discussion with an interesting outcome. I believe other participants will benefit from reading it.
Rick
Rick
Hi Richard, I did turn every color getting this fixed - thank you again for your help.  I seem to have forgotten that a routing statement is needed :-/
I've put in specific routing statements into the configs so now I can move ahead and add the overload NAT and incoming PAT.
R1 ip route 192.168.176.0 255.255.255.0 192.168.168.236
R2 ip route 192.168.175.0 255.255.255.0 192.168.168.235
I found a really good example for multiple IPSEC tunnels that helped me.   https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/14133-ios-hub-spoke.pdf
I got the overload NAT and port mapping working.  :-)  Thanks for your help.
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#sh run
Current configuration : 3766 bytes
! Last configuration change at 17:22:42 UTC Tue Dec 18 2018 by cisco
! NVRAM config last updated at 18:12:13 UTC Tue Dec 18 2018 by cisco
version 15.4
hostname localrtr
boot-start-marker
boot-end-marker
no aaa new-model
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.175.1 192.168.175.2
ip dhcp excluded-address 192.168.175.64 192.168.175.255
ip dhcp pool DHCPPOOL
 network 192.168.175.0 255.255.255.0
 dns-server 192.168.168.200 192.168.168.1
 default-router 192.168.175.1
 lease 0 2
no ip domain lookup
ip cef
no ipv6 cef
cts logging verbose
voice-card 0
hw-module pvdm 0/0
redundancy
 encr 3des
 hash md5
 group 2
 mode tunnel
 no ip address
 shutdown
 description OUTSIDE
 ip access-group REMOTE_OUTSIDE_IN_ACL in
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 crypto map CMAP
 description INSIDE
 ip nat inside
 duplex auto
 speed auto
 no ip address
 duplex auto
 speed auto
 no ip address
 no ip address
 no ip address
 no ip address
interface Vlan1
 no ip address
interface Vlan200
no ip http server
ip nat inside source static tcp 192.168.175.66 80 interface GigabitEthernet0/0 8080
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.168.1
ip access-list extended REMOTE_OUTSIDE_IN_ACL
 permit tcp host 192.168.168.140 host 192.168.168.235 eq 8080
 deny   tcp any host 192.168.168.235 eq 8080
 deny   udp any host 192.168.168.235 eq 8080
 permit ip any any
access-list 100 remark -=[Define NAT Service]=-
access-list 100 deny   ip 192.168.175.0 0.0.0.255 192.168.176.0 0.0.0.255
access-list 100 permit ip 192.168.175.0 0.0.0.255 any
control-plane
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no exec
 transport input all
 stopbits 1
line vty 0 4
 login local
 transport input ssh
ntp server 10.10.10.30
end
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
localrtr#
Allan
I am glad that you found a helpful reference for multiple tunnels. Thank you for sharing it with us. Hopefully some other participants in the community will also find it helpful.
This community can be a very helpful resource. And with the community you are not alone. I hope to see you continue to be active in the community.
Rick
Rick
