IPSEC VTI issues
abid1
Frequent Visitor
Frequent Visitor
I have configured SVTI between two routers, if we shutdown the tunnel interface then the tunnel at both ends goes down but when we shut down physical interface at one end then the other side tunnel still up and it goes down after 40 mins.
Thanks for the comments in Advance
5 Replies 5
Georg Pauwen
what are your tunnel source interfaces ? Post the configs of both ends...
Tunnel source is physical interface IP (link is L2VPN)
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key MYIPSEC address 10.1.1.1
 crypto ipsec transform-set esp-3des esp-3des esp-sha-hmac
mode tunnel
crypto ipsec profile IPPROF
set transform-set esp-3des
interface Tunnel3344
ip address 192.168.75.2 255.255.255.252
keepalive 3 6
tunnel source 10.1.1.1
tunnel mode ipsec ipv4
tunnel destination 10.1.1.2
tunnel protection ipsec profile IPPROF
Hello
By default tunnels will not be aware of the link state of the endpoint physical interface and as such it will not be brought down by its failure.
Please read this -
Kind Regards
Paul
Dear Paul,
What is the work around to get the tunnel interface go down if destination is not reachable
Syed
Hello
@abid1 wrote:
Dear Paul,
Syed
As the tunnel is stateless I dont think you can do this this unless you manually apply some form of tracking like IP SLA & EEM.but i can be wrong anyway below is a example IP SLA and EEM
(apply to both rtrs)
ip sla 1
icmp-echo (tunnel endpoint destination) source-ip  (tunnel source destination)
ip sla schedule 1 life forever start-time now
track 10 rtr 1 reachability
event manager applet Tunnel-destination-down
event track 10 state down
action 5.0 cli command "enable"
action 5.1 cli command "conf t"
action 5.2 cli command "interface tun xx"
action 5.3 cli command "shut"
action 5.4 cli command "end"
event manager applet Tunnel-destination-up
event track 10 state up
action 5.5 cli command "enable"
action 5.6 cli command "conf t"
action 5.7 cli command "interface tun xx"
action 5.8 cli command "no shut"
action 5.9 cli command "end"
Kind Regards
Paul
