10-01-2011 06:44 AM - edited 03-04-2019 01:47 PM
one of my client wants to establish IPsec tunnel with my office and he has provided tunnel properties in PHASE 1 and PHASE 2 .
can somebody provide me the sample config according to these properties.
PHASE 1 :
Authentication mode : Pre-shared key
Encryption scheme : IKE
DH group : Group 2
Encrytion Alogorithm : 3DES/AES-128,192,256
Hash Algorithm : MD5/SHA
Main or aggresive mode : main
lifetime : 86400/28800
PHASE 2 :
Encapsulation : ESP
Encryption algorithm : 3DES
Authentication mode : MD5/SHA
PFS with Algorithm : group 2
lifetime : 28800/3600
lifesize in KB : NA
what i didn't understand is why he has provided values two times. a little explanation will help.
10-01-2011 08:52 AM
Tunnel is formed of different proccess, called different phases while creating a tunnel.
Which are IPSec Authentication Header (AH), IPSec Encapsulating Security Payload (ESP) and the IPSec Internet Key Exchange (IKE).
You are provide with those information, as what to use in that particular phase.
And regarding configs, a little playing with router or google will provide you a sample config...
HTH,
Smitesh
10-01-2011 10:12 AM
Phase 1 with IPSEC is about setting up a secure connection to the remote device. It does not deal with setting up the actual tunnels used to transmit the data. The commands used to setup phase 1 are "isakmp ..." or "crypto isakmp .." commands depending on whether you are using a firewall like the pix/ASA or a router.
Phase 2 with IPSEC is then about setting up the actual tunnels for transmitting the data. This can only be done once a secure connection using Phase 1 has been done.
There is no requirement to use the same encryption algorithms etc. for each Phase ie. they can be different if you want.
For config examples see this link -
http://www.cisco.com/en/US/customer/tech/tk583/tk372/tech_configuration_examples_list.html
Jon
