IPSec
abdul.qadir5001
In IPSec Tunnel phase 1 is up and phase 2 is not up then whats the issue of it. Thanks
phase 2 usually means a problem with the IPSec SA parameters. Do you have a debug output, or better yet, the configs of both sides ?
Please check the phase two configurations. If you have similar properties configured in both the tunnel end point.
crypto ipsec configuration like hashing is same and if modes are same like tunnel and transport.
Make sure no deny of IP protocol number 50 and 51.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
