IPV4 DHCP on router
scsawyer
Hello All
I would like to extend the ip address range for the router, but not working like i though it would.
ip dhcp pool Pool
import all
network 192.168.35.0 255.255.254.0
default-router 192.168.35.1
domain-name gleamns
dns-server 8.8.8.8 4.4.4.4
lease 0 2
interface Vlan1
ip address 192.168.35.1 255.255.255.0
ip nat inside
ip nat enable
ip virtual-reassembly in
ip virtual-reassembly out
which gives me 512 host, but the ones that get the .34 range are not able to connect
access-list 101 is missing ?
9 Replies 9
sure not work the SVI which is GW 255.255.255.0 have mask different than host  255.255.254.0
only match the mask for both GW and host and it will work
make the changes marked in bold, when you are done, post the full running config again (sh run) so we can doublecheck...
ip dhcp pool center
import all
--> network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
--> no domain-name Domain1
--> dns-server 8.8.8.8
lease 0 2
interface GigabitEthernet4
description outside wan 2
ip address dhcp
--> ip nat outside
duplex auto
speed auto
interface GigabitEthernet5
description outside wan1
ip address dhcp
--> ip nat outside
duplex auto
speed auto
interface Vlan1
--> ip address 192.168.100.1 255.255.255.0
ip nat inside
--> no ip nat enable
no ip virtual-reassembly in
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map ISP_1_RM interface GigabitEthernet4 overload
ip nat inside source route-map ISP_2_RM interface GigabitEthernet5 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet5 dhcp
ip route 0.0.0.0 0.0.0.0 GigabitEthernet4 dhcp
route-map ISP_1_RM permit 10
match ip address 101
match interface GigabitEthernet4
route-map ISP_2_RM permit 10
match interface GigabitEthernet5
access-list 23 permit any
--> access-list 101 permit ip 192.168.100.0 0.0.0.255 any
access-list 104 permit ip any any
access-list 104 deny ip any any
access-list 110 permit ip any any
@Georg Pauwen has answer your perfectly.
if not work then share final config and we will make double check.
ok thanks for all the help, I think it is working, I will have to take it out on site to make sure, the only thing i see is that the DHCP with it configured with the 255.255.255.0 it will not give out enough IP Addresses, if i could use the  255.255.254.0 that would give me 512 addresses, but how would you get the rest of it to work with that setting?
I am puzzled by the response from Georg which seems to address an environment different from what is described in the original post. Basically your issue is that there is a mismatch between your pool configuration which is a network /23 and your interface which is /24. It seems to me that if you change the mask on your vlan1 interface to 255.255.254.0 that it should work.
Rick
can you share you config
ok here is what i have at this time, it will pull IP Addresses but will not browse the internet
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool center
import all
network 192.168.100.0 255.255.254.0
dns-server 8.8.8.8
lease 0 2
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
ip address dhcp
ip nat outside
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
ip address 192.168.100.1 255.255.254.0
ip nat inside
ip nat enable
ip http server
Thank you, it seems to be working now. I hate access list sometimes.
I appreciate everyone's input.
