05-26-2012 02:48 PM - edited 03-04-2019 04:28 PM
Hi guys,
If NAT is configured on a boundary router and is set on the inside and outside interfaces, but show ip nat translations doesn't show any information.
Why might the problem be?
05-26-2012 05:16 PM
Either your traffic isn't getting routed to the router or the NAT config has an error. Can you post the relevant configuration?
05-29-2012 05:15 AM
NAT config"
ip nat pool POOL1 1.1.0.0 1.1.0.255 prefix-length 16
ip nat inside and outside are set to the interfaces as well.
05-29-2012 05:35 AM
Your NAT is incomplete please try this:-
access-list xx permit (internal traffic)
ip nat inside source list xx pool POOL
Please let us know if this solving your issue.
