IPv4 NATs not working
jseilerwfg
I've been struggling for this one now for about 3 weeks.
We have a router that boarders a B2B connection and within the config we NAT our internals to a specific set of addresses.
So, for example (addresses have been changed from production):
ip nat inside source static 192.168.1.22 192.168.2.22
ip nat inside source static 192.168.1.23 192.168.2.23
ip nat inside source static 192.168.1.27 192.168.2.27
ip nat inside source static 192.168.1.28 192.168.2.28
ip nat inside source static 192.168.1.77 192.168.2.77 <--- Problem child
ip nat translation timeout 300
What I am running into is the 192.168.1.77 inside local (aka Real) is a DNS server that forwards requests to another DNS server across our B2B connection.  Every-so-often, the router decides to stop translating the address and nobody can access certain hosts. I have to issue 'clear ip nat translation *' to get it working aging.
2811 Running 12.4(24)T3
TIA!
5 Replies 5
handoko wiyanto
Level 3
Level 3
Did you check the cpu and memory utilization before clearing the nat translation?
Yep, It's snoozing
For what its worth my strange NAT problems have always be resolved with an IOS change.
James
Yeah, I'm thinking about jumping up to T5 on the current train.  I've also had it freak out when using object-groups in ACLs
hi,
how much dram and flash do you have for that router?
i was reading release note here
http://www.cisco.com/en/US/docs/ios/12_4t/release/notes/124TCAVS.html
it seems that those T releases do have problems with nat
well, perhaps T5 is a good start, but im suggesting you start with T7, it resolve quite important bug:
CSCtg47129
Symptoms: A memory leak is seen when NAT is configured.
Conditions: This symptom is observed when NAT is configured.
Workaround: There is no workaround.
regards,
