IPv6 ND - Default route not installed
oscarjramirez
I'm trying to install a default IPv6 route through RA ND on a serial link. This is my configuration:
R4#
ipv6 unicast-routing
interface Serial0/1
description Connected to R5
ipv6 address 2001:4444::/64 eui-64
ipv6 nd prefix 2001:4444::/64 infinite infinite
no ipv6 nd ra suppress
end
R5#
no ipv6 unicast-routing
interface Serial0/1
description Connected to R4
ipv6 address autoconfig
The result with this configuration is:
R5#sh ipv6 int s0/1
Serial0/1 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::20D:BCFF:FE26:7F70
  No Virtual link-local address(es):
  Description: Connected to R4
  Global unicast address(es):
    2001:4444::20D:BCFF:FE26:7F70, subnet is 2001:4444::/64 [EUI/CAL/PRE]
  Joined group address(es):
    FF02::1
    FF02::1:FF26:7F70
  MTU is 1500 bytes
  ICMP error messages limited to one every 100 milliseconds
  ICMP redirects are enabled
  ICMP unreachables are sent
  ND DAD is enabled, number of DAD attempts: 1
  ND reachable time is 30000 milliseconds
  Default router is FE80::211:5CFF:FEBA:4260 on Serial0/1
R5#
R5#sh ipv6 route
IPv6 Routing Table - 3 entries
C   2001:4444::/64 [0/0]
     via ::, Serial0/1
L   2001:4444::20D:BCFF:FE26:7F70/128 [0/0]
     via ::, Serial0/1
L   FF00::/8 [0/0]
     via ::, Null0
R5#
So far so good, but I tried with another link between FastEthernet interfaces on Catalyst 3560 switches:
SW4#sh ipv6 int f0/20
FastEthernet0/20 is up, line protocol is up
  IPv6 is enabled, link-local address is FE80::223:34FF:FE20:E8C2
  Description: to SW3 F0/20
  Stateless address autoconfig enabled
    2001:44::223:34FF:FE20:E8C2, subnet is 2001:44::/64 [EUI/CAL/PRE]
    FF02::1
    FF02::1:FF20:E8C2
  MTU is 1500 bytes
  ND reachable time is 30000 milliseconds (using 24342)
  Default router is FE80::AEA0:16FF:FEAC:C6C2 on FastEthernet0/20
SW4#
SW4#sh ipv6 route
IPv6 Routing Table - Default - 4 entries
S   ::/0 [1/0]
     via FE80::AEA0:16FF:FEAC:C6C2, FastEthernet0/20
C   2001:44::/64 [0/0]
     via FastEthernet0/20, directly connected
L   2001:44::223:34FF:FE20:E8C2/128 [0/0]
     via FastEthernet0/20, receive
L   FF00::/8 [0/0]
     via Null0, receive
SW4#
So, my question is, what I need to get installed the default route in the serial link scenario?
Thanks in advance!!!
Oscar Ramirez.
7 Replies 7
cadet alain
just by doing this: ipv6 unicast-routing
Regards.
Alain.
Thanks Cadet, but I already tried it. It must be applied only on the server router, the client must not have it.
Hi Oscar,
If your router is an IPv6 host then how can he have a default route in its routing table?
try again and shut/no shut the interface.
if it doesn't work I'll lab it up.
Regards.
Alain.
Hi Alain,
Indeed I put the two scenarios. In the 3560s link, the server device sends RA with the prefix (it has ipv6 unicast-routing configured) and the client (ipv6 unicast-routing disabled) puts the default "::" on its routing table.
In the 3725 serial link, it doesn´t result. I don't know what can be happening.
Oscar.
In fact, this should be the behavior for the serial link:
06:08:25: ICMPv6-ND: Selected new default router FE80::AEA0:16FF:FEAC:C6C2 on FastEthernet0/20
06:08:25: ICMPv6-ND: Installed default to FE80::AEA0:16FF:FEAC:C6C2 on FastEthernet0/20
Oscar.
Hi Oscar,
thanks for the info.
Regards.
Alain.
oscarjramirez
It's an IOS matter. I tried with 12.4(24)T and it works fine. Thanks a lot.
