ipv6 next-hop
aconticisco
Level 2
Level 2
for some reason when I apply the IP next hop the concerning route disappers from the route BGP list even though the same next hop can be pinged without any issues from the router on which I expect the route to show. This happens on both routers (directly connected) and if I remove the route-map that applies the relevant next hop I get the route listed but with an auto created Next Hop address such as:
::FFFF:172.16.12.2
Cannot find any reason why this should not work as when I see the route table the respective set next hop subnet is there so reachable.
Philip D'Ath
What platform and software version are you running?
5 Replies 5
Philip D'Ath
Router#SHOW VERSION
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 12.4(24)T5, RELEASE SOFTWARE (fc3)
Can you give the output of "show inventory" as well please.
NAME: "Chassis", DESCR: "Cisco 7206VXR, 6-slot chassis"
PID: CISCO7206VXR
NAME: "NPE400 0", DESCR: "Cisco 7200VXR Network Processing Engine NPE-400"
PID: NPE-400
NAME: "module 0", DESCR: "I/O FastEthernet (TX-ISL)"
PID: C7200-IO-FE-MII/RJ45=,
NAME: "module 1", DESCR: "FastEthernet"
PID: PA-FE-TX
I can't even find that release available for download, and this is quite an old platform.
Are you able to deploy something a bit more modern like 15.1.4M10 ?
