IPV6 on BVI Interface: Not working
Matthew Millman
Setup: PC (2001:8B0:122E:F25B::2) <----> Router (1921) (Gi0/1    2001:8B0:122E:F25B::1)
Running: 15.2(4)M2
---- Working ----:
no ipv6 source-route
ipv6 unicast-routing
ipv6 multicast-routing
ipv6 cef
interface GigabitEthernet0/1
ipv6 address 2001:8B0:122E:F25B::1/64
ipv6 enable
With the above configuration, The PC can ping the switch.
But as soon as I change it to this:
ipv6 cef
  bridge-group 1
interface BVI1
ipv6 enable
bridge 1 protocol ieee
bridge 1 route ip
Then it's broken. In this setup, some IPv6 is working, i.e. the PC can see router advertisments, but from looking at packet debug, it seems that the ICMPv6 neighbor solicitations do not make it to the BVI interface, hence it not working. But why? IPv6 has supposed to have been working on BVI interfaces for quite some time now...
Hi Matthew,
I am glad to hear it works now. I think you should discuss with your Cisco account team and make them aware of the situation. They will be able to help you with the licencing issue given that the datak9 technology package is only required for the work around.
12 Replies 12
Harold Ritter
Hi Matthew,
IPv6 should indeed be supported on a BVI interface in this version. I found a bug that could be a match for the behavior you are seeing. Could you post the output of a "show ver" for this 1921.
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 07-Nov-12 12:45 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
Edge uptime is 19 hours, 16 minutes
System returned to ROM by reload at 10:08:32 UTC Sat Aug 10 2013
System image file is "flash:c1900-universalk9-mz.SPA.152-4.M2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID
1 DSL controller
1 Ethernet interface
6 Gigabit Ethernet interfaces
1 ATM interface
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
data          None          None           None
Hi Matthew,
It appears that you came across CSCtl43156. You can load the datak9 technology package as a workaround. Can you run the following command then reload the box and see if it fixes the issue.
license boot module c3900 technology-package datak9
Just looking at that bug
A) It says that it's only present _when_ the data package is running (which mine isn't)
B) It also says fixed in releases which are all older than ones I've tried and seen the issue on
C) This is really not a router I want to go rebooting unless I absolutely know I have to -
You sure about that?
Hi Matthew,
This is not a sure shot indeed. I have seen a TAC case though, where the issue is the same you are seeing and it got solved using the suggested workaround. I unfortunately do not have the required setup to test it at the moment.
I have not found any other obvious bugid explaining why ipv6 does not work for you on the BVI interface.
Tried that and tried upgrading to 15.2(4)M4
It appears that IPv6 on BVI remains broke.
Probably time to escalate to customer support...
Hi Matthew,
Could you post another "show ver" and the entire config if possible.
Config posted below
Matthew Millman
The original configuration is more than 1000 lines long (and confidential) so I won't be posting that here
However I have just taken it out of service so I can deal with this issue so can now post a default config with the BVI on IPv6, which is:
version 15.2
hostname Router
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.152-4.M4.bin
boot-end-marker
no aaa new-model
ip cef
ipv6 cef
license udi pid CISCO1921/K9 sn
vtp mode transparent
redundancy
controller VDSL 0/0/0
vlan 2-9
bridge irb
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
bridge-group 1
no ip address
shutdown
duplex auto
speed auto
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
no ip address
shutdown
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface Vlan1
no ip address
interface BVI1
no ip address
ipv6 enable
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 1 route ip
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 12:49 by prod_rel_team
Router uptime is 3 minutes
System returned to ROM by reload at 12:43:24 UTC Sun Aug 18 2013
System image file is "flash:c1900-universalk9-mz.SPA.152-4.M4.bin"
export@cisco.com.
Processor board ID
1 DSL controller
1 ATM interface
1 terminal line
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9
data          None          None           None
With the above configuration/version: Same behavoir: as soon as IPv6 is moved to the BVI, it ceases to function. Packets egress from the BVI, but no ingress.
Hi Matthew,
The "show ver" output still indicates that datak9 is not active. Could you please activate it with the following command, reload the router and retry the ipv6 ping.
Router> enable
Router# configure terminal Router(config)# license boot module c1900 technology-package datak9
Okay, now it works.
So where does that leave me? depending on a licence pack I don't own to make this work?
Router uptime is 2 minutes
System returned to ROM by reload at 13:19:21 UTC Sun Aug 18 2013
export@cisco.com.
Processor board ID
1 DSL controller
1 ATM interface
1 terminal line
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9
data          datak9        EvalRightToUse datak9
Hi Matthew,
