IR1100 multicast problem
orbutbul123
I'm trying to set a multicast environment with IR1101 as the router.
I've connected a multicast source to one interface of the router and a multicast listener to another interface. I've configured PIM sparse mode on both interfaces and on a loopback interface.
I set the loopback interface as an RP. I've checked if unicast works between the source and the listener, and it doesn't.
However the router won't forward multicast packets.
I've checked the same exact configuration on an ISR4000 router, and it work like a charm.
Has anyone encountered such an issue with IR1101?
Was anyone able to set up multicast forwarding on IR1101?
Router version -17.4.1
with advantage license in use.
0 Replies 0
