3 routers in HSRP
grapevine
If there are three routers in a HSRP group, one will be active , other will be standby, what will be the state of the third - will it be also in Standby or in Speak
Hello
It will be in a listening state.
Kind Regards
Paul
Hi ranjipremandrewp ,
For one HSRP group only one device can be in ACTIVE state and only one device will be in Standby state , Rest all devices will stay in Listening state . If any device in Active or Standby state fails , in that case the devices in listening state will change their state to Active or standby depending upon the device that went down .
Spooster IT Services Team
This is a nice elaboration explaining the logic of the correct response from Paul. So +5
Rick
https://www.cisco.com/c/en/us/support/docs/ip/hot-standby-router-protocol-hsrp/10583-62.html
Listen status
""The router knows the virtual IP address, but the router is neither the active router nor the standby router. It listens for hello messages from those routers.""
